[Printer]User defined Size Problem (Landscape)
Post bug reports and suggestions for TextMaker 2008 for Windows.
coco
Post by coco » Thu Feb 11, 2010 4:38 am
PDF Printer: novapdf
Left:Print Job
Center:Page Setup
Right:TextMaker
Orientation.doc
Example
(8.5 KiB) Downloaded 255 times
coco
Re: [Printer]User defined Size Problem (Landscape)
Post by coco » Thu Feb 11, 2010 4:57 am
Orientation Inheritance Problem
print.doc
(8.5 KiB) Downloaded 246 times
Post by sven-l » Thu Feb 11, 2010 10:40 am
Hello,
did you also tested it with TextMaker's PDF export or only with novapdf? Does it work better with Office 2010? You can download a trail version here:
http://www.softmaker.com/english/ofwdemo_en.htm
coco
Post by coco » Thu Feb 11, 2010 4:30 pm
only with novapdf (Printer export)
Softland say "This is not an Softland bug"
-we'll look in the landscape/portait page switching problem, it seems that indeed the page layout is not kept in some cases for Textmaker.
Copy from dopdf forum
http : //www.dopdf.com/forum/topic/textmakerdiff ... ion-method
download now...waiting
Softland say "This is not an Softland bug", if Softmaker also say "This is not an Softmaker bug"..... O...TL
Post by sven-l » Thu Feb 11, 2010 4:47 pm
Pleae try it with the PDF export in TextMaker (File=>Export as PDF). Different PDF printer from different companies produces different outputs. That's why I asked if the probpem still exist with the internal PDF export function of TextMaker 2010.
coco
Post by coco » Thu Feb 11, 2010 5:23 pm
internal PDF export, no problem.
but, I like doPDF/novapdf output...
TextMaker 2010 trail version
Printer export: TextMaker 2010 also have this problem
Internal PDF export: no problem
Printer export: no problem
Post by sven-l » Fri Feb 12, 2010 8:26 am
coco wrote:>Pleae try it with the PDF export in TextMaker
If it works with the internal PDF export but not with an 3rd party application there is unfortunately nothing we can do here. You can try it with another PDF printer if you like (freePDF, cutePDF and so on).
Return to “TextMaker 2008 for Windows”
