Can a template be saved for handout master?
Post bug reports and suggestions for SoftMaker Presentations 2008 for Windows.
jrm123
Post by jrm123 » Sun May 18, 2008 1:42 pm
Hi
Using Presentations Handouts are a part of the deal. When setting up the handout master as I wish to use on a number of occasions it would be helpful to be able to save a custom master for using next time rather than having to re-create it every time.
Maybe there is a method I haven' found yet.
Cheers
John
Re: Can a template be saved for handout master?
Post by Jossi » Tue May 20, 2008 1:00 am
Open a new empty file, set up your handout master the way you wish and save as SoftMaker Presentations template (*.prv).
Return to “SoftMaker Presentations 2008 for Windows”
