Automated printing
Post bug reports and suggestions for SoftMaker Presentations 2008 for Windows.
CDAlan
Automated printing
Post by CDAlan » Tue Apr 01, 2008 1:54 am
I'm using a Windows virtual print driver to open and "print" my files in an automated fashion. This is working great with TextMaker but not with PlanMaker or Presentations 2008. Basically the driver just opens the file using the default application (PlanMaker for instance) and triggers a print command. This works for TextMaker files but not PlanMaker or Presentations. Any Ideas?
amuehl
Re: Automated printing
Post by amuehl » Thu Apr 03, 2008 1:59 pm
I've forwarded your inquiry to our developers and will inform you as soon as I have news regarding this issue.
Alexander Mühl
amuehl
Post by amuehl » Mon Apr 07, 2008 3:04 pm
Our developers need more information to help you:
For example, we have no clue about what you mean with "Windows virtual print driver". Furthermore we need to know in which way you are printing: Do you manually open the files, do you use the /p paramter for printing, OLE Automation, or even DDE? Please give us as much details as possible.
Alexander Mühl
CDAlan
Post by CDAlan » Mon Apr 07, 2008 6:31 pm
I'm using Print2Flash. http://print2flash.com. It installs in windows as a virtual printer - printer driver. When you print to this "printer" it just saves a .swf file of the printed contents. Instead of manually invoking the print process I'm using their OLE automation API so I can convert documents in an automated fashion.
More about their OLE automation API here:
http://print2flash.com/help/AboutAutomationAPI.php
Thanks, and if you need more info or need me to test anything please let me know.
amuehl
Post by amuehl » Tue Apr 08, 2008 9:30 am
Thank you. Hope that helps to solve this issue.
Alexander Mühl
CDAlan
Post by CDAlan » Fri Apr 18, 2008 12:36 am
Just following up to see if there's any news. Is this something that I may be able to work around in some way or is it going to require an update to the program?
Thanks!
amuehl
Post by amuehl » Fri Apr 18, 2008 8:46 am
I'm sorry, but currently there are no news regarding your inquiry. I will raise the priority of your ticket.
Alexander Mühl
amuehl
Post by amuehl » Mon Apr 21, 2008 1:23 pm
Our developers have encountered some printing-issues with PlanMaker and Presentations. All these issues have been fixed now and will probably be part of the next service pack for SoftMaker Office 2008.
Alexander Mühl
CDAlan
Post by CDAlan » Mon Apr 21, 2008 8:55 pm
Great news - thanks - I'll reply with my findings once I'm able to install this service pack and test.
CDAlan
Post by CDAlan » Mon Apr 21, 2008 8:59 pm
Also, what sort of time frame until that service pack is available? (rough estimation is fine)
amuehl
Post by amuehl » Tue Apr 22, 2008 8:28 am
Hello,
we are currently testing the service pack, so it will be released in a few weeks.
Alexander Mühl
CDAlan
Post by CDAlan » Sat May 17, 2008 9:03 am
Any new news on how close we are to the release of this service pack?
Thanks!
Post by sven-l » Mon May 19, 2008 10:02 am
Hello,
the new Service Pack for SoftMaker Office 2008 for Windows will be available very soon. You will be informed via our newsletter.
Return to “SoftMaker Presentations 2008 for Windows”
