I cannot install Office's trial v2006 in my HP Jornada 728
Help for TextMaker 2006 for Handheld PCs
milciades
Post by milciades » Mon May 12, 2008 5:15 am
I have a HP Jornada 728, when I install Office 2006 for Win CE, using Active Sync, it is installed right in the PC has Windows XP Professional. When installing, require it than in the Jornada do it in a Storage Card. The result is that copy folders and files, the executable included into a so-called directory " Softmaker Office 2006...", But you do not install it really.
So much the Texmaker, like the Planmexer, using the executable yields a message of error when choosing to initiate. That you say: Do not find the route or there is not enough some element or .dll.
Trial receives treatment of the version. That can I make this problem resolve? [-o<
Re: I cannot install Office's trial v2006 in my HP Jornada 728
Post by sven-l » Tue May 13, 2008 10:18 am
Hello,
did you receive a error message during the installation process?
Please try again to install the SoftMaker Office 2006 on your Windows CE device. If the error messages during the initiation of TextMaker and PlanMaker continues please write the exact error mesasge in the forum. Thank you!
Return to “TextMaker 2006 for Handheld PCs”
