Installing Softmaker 2006 for MobilePro 900c and Storage car
Help for TextMaker 2006 for Handheld PCs
evieabston
Post by evieabston » Mon Feb 04, 2008 10:32 am
Hi:
I love your program. My two questions are one, what are the steps for installing the software on a Storage card. Do I put the card in the mobile pro and then select that option or do I send it to a storage card via my desktop and two, how can I save my textmaker documents on a storage card. There doesn't seem to be an option and i need to save storage space when I can. My MobilePro 900c is only 64MB so I want to save on a storage card whenever possible.
Thank you.
Tobias-L
Re: Installing Softmaker 2006 for MobilePro 900c and Storage car
Post by Tobias-L » Mon Feb 04, 2008 10:37 am
Simply plug the storage card into your NEC, connect the MobilePro to your desktop PC via ActiveSync. Now start the installer from your desktop PC. You will find an option to install to internal memory or to a storage card.
Tobias Leißner
Reel Jemm
Post by Reel Jemm » Fri Aug 01, 2008 2:44 pm
I realize that this is an old post - notwithstanding, if anyone is interested, SoftMaker Office 2006 for Windows CE fits on the internal disk on my NEC Mobile Pro 900. Not sure if you have as much free space on the internal disk on the 900C... something worth checking.... Key advantages to having it installed to the internal disk is that it's much faster and preserved in case of a crash. Cheers!
Uncle Ben
Return to “TextMaker 2006 for Handheld PCs”
