Crash on formulas
Help for PlanMaker 2006 for Linux and FreeBSD
francisco
Crash on formulas
Post by francisco » Tue Jun 05, 2007 4:44 pm
PlanMaker 2006 for FreeBSD
Rev 316
I often have crashes when I insert a fomula into an existing spreadsheet.
A formula as simple as
=819.72/12
After some trial and error I think I found what causes the crash.
If the number getting divided has decimal, it crashes.
If I change the formula to =819/12 it works.
Tobias-L
Post by Tobias-L » Tue Jun 05, 2007 4:57 pm
Are you able to run the software via strace and send us the relevant crash error log via email (forum(at)softmaker.de)? This would be very helpful.
Additionally, what Linux distro are you using?
Tobias Leißner
Post by martin-k » Tue Jun 05, 2007 10:09 pm
He mentions FreeBSD, so the question regarding the Linux distro doesn't apply... :wink:
But (to the original poster): Why do you use revision 316, when we are already at revision 320?
francisco
Post by francisco » Wed Jun 06, 2007 9:25 pm
martin-k wrote:But (to the original poster): Why do you use revision 316, when we are already at revision 320?
Just downloaded 320.
Seems to be working without the crash.
will report back if it crashes again with 320.
Thanks.
Return to “PlanMaker 2006 for Linux and FreeBSD”
