Bug? Can't undo format copy
Help for PlanMaker 2006 for Linux and FreeBSD
francisco
Post by francisco » Sat Dec 30, 2006 6:26 am
Just did a format copy.. and then tried to undo. Undo did not work.
Format changes are not tracked by undo?
amuehl
Post by amuehl » Wed Jan 03, 2007 1:34 pm
Hello,
Format changes in cells are tracked by undo, but only if you do them manually. If you use the "Transfer cell formatting with mouse"-icon, undo will not track your steps.
I'm not sure, if this works as designed or if this is a bug, but I will write a bug report to our developers and post the answer into this thread.
Alexander Mühl
amuehl
Post by amuehl » Wed Jan 03, 2007 4:54 pm
Our developers just told me that this issue will be fixed within the next service pack. Thanks for your feedback.
Alexander Mühl
Return to “PlanMaker 2006 for Linux and FreeBSD”
