It's not possible to print with latest update
Tommy_CZ
Post by Tommy_CZ »
Printing on Linux with latest update is broken, after print to printer (KonicaMinolta) it says "postscript/pdf creation failed error code 43" and print the document with scrambled fonts.
Before update it worked as expected.
Printing with LibreOffice etc. works as expected.
I use KDE NEON 64bit - Ubuntu LTS 20.04.1
TextMaker 2021 (rev S1024.1204) 64bit
Re: It's not possible to print with latest update
Thanks for reporting this problem. Please try to print to PDF file and check if that works. Please also let us know your printer name which is showing on your printer dialog box when you are printing.
Tommy_CZ
Post by Tommy_CZ »
Well, PDF is created without problems.
Personally I don't understand why it shows error of PDF creating, when no PDF is created during printing.
I use KonicaMinolta Bizhub C3351
Thanks for reporting this problem. Please share the associated file in which you are getting this problem so that we can do further investigation for resolution. Please also check if there are any parentheses etc in your printer's name.
viewtopic.php?f=392&t=20679
