Installing a new language
Help for TextMaker 2006 for Pocket PCs
Pryan
Post by Pryan » Sun Nov 25, 2007 10:34 pm
I have installed Office 2006 with the default settings, and now i want to install the spanish lang. To do this i copy the file TextMaker_es.dwr to the directory of TM, but when i try to load it in TM it says that the language is not installed. What i must to do ?
Tobias-L
Re: Installing a new language
Post by Tobias-L » Mon Nov 26, 2007 8:53 am
This file is for the GUI only. Do you want to install dictionaries or the user interface language?
Please rerun the installer to install additional languages.
Tobias Leißner
Pryan
Post by Pryan » Mon Nov 26, 2007 10:15 am
I want to install the user interface language.
There is no way to do this without reinstalling the software ?
Tobias-L
Post by Tobias-L » Mon Nov 26, 2007 10:19 am
You can install the user interface language onto the Pocket PC by copying the *.dwr files to the same directory where the TextMaker executable is located. After a restart of TextMaker you should be able to change the GUI language via Extras :arrow2: Preferences :arrow2: Appearance
What exactly do you mean with "TM says that the language is not installed"? Do you get an error message?
Tobias Leißner
Pryan
Post by Pryan » Mon Nov 26, 2007 12:04 pm
Yes, i get an error message.
I copy the .dwr file from the windows installation and when i try to load it says to me the error message.
Could you attach me the file TextMaker_es.dwr of PPC version to test if it loads correctly ?
Tobias-L
Post by Tobias-L » Mon Nov 26, 2007 12:10 pm
Please don't use the desktop Windows dwr file on your Pocket PC. It won't work.
Please download the full version again, extract the files using WinZIP (it's a self-extracting EXE file) and go to the COMMON folder. There you will find the dwr files you need.
Tobias Leißner
Pryan
Post by Pryan » Mon Nov 26, 2007 6:00 pm
OK, it works, a lot of thanks :)
Return to “TextMaker 2006 for Pocket PCs”
