Sluggish performance with external references
Post your questions, bug reports and suggestions here for PlanMaker 2018 for Mac.
paps
Post by paps » Mon Jun 18, 2018 1:19 am
Hi.
I'm starting to use Planmaker for mac.
In general, I like the program very much, but I have noticed a very sluggish performance when dealing with excel files that include an external reference.
Even when you tell Planmaker for mac to not update the external references (because it is unable to locate the source file), the program gets very slow to a point is a pain to use.
In the same file, when using pivotables with an excel spreadsheet of around 3,300 rows and about 35 to 40 columns, pivotables get really slow. I don't know if it it related to the problem with the external references or not. But please check it.
Thank you!!
Re: Sluggish performance with external references
Post by sven-l » Tue Jun 19, 2018 9:31 am
Please provide a sample file that helps us solving this issue. Upload it here or send it to forum(at)softmaker.com.
paps
Post by paps » Wed Jun 20, 2018 4:46 am
I would love to, but I can’t.
It is an internal document from my office, that I can’t upload.
But you should be able to replicate the sluggish behavior with another excel file with external references that are not available.
Regards,
Post by sven-l » Thu Jun 21, 2018 10:09 am
Ok, I will try to reproduce that issue here.
Return to “PlanMaker 2018 for Mac”
