TextMaker on OpenBSD 3.5
Help for TextMaker 2002 for Linux and FreeBSD
jon-d
Post by jon-d » Wed Sep 08, 2004 4:10 am
* Install the port /usr/ports/emulators/redhat/
* Uncomment the line #kern.emul.linux=1 in /etc/sysctl.conf see
* http://www.openbsd.org/faq/faq9.html#Interact , section 9.4.
* Get TextMaker and unpack it in /emul/linux/
* In your ~/.bashrc or ~/.kshrc enter the following line: export LD_LIBRARY_PATH=/usr/X11R6/lib:$LD_LIBRARY_PATH
* In your ~/.profile add the following: ENV=$HOME/.kshrc; export ENV (or ENV=$HOME/.bashrc).
* Run TextMaker by typing /emul/linux/textmakertrial/tml, in a Xterm.
To see these instructions as written up in TextMaker, download the *.pdf from here:
http://www.silbsd.org/projects/TextMakerOpenBSD.pdf
Post by martin-k » Wed Sep 08, 2004 2:56 pm
Thank you for this information! We incorporated a reference to this on our features page at http://www.softmaker.de/tmldetail_en.htm (scroll down to system requirements).
Have you tried the same route with PlanMaker?
jon-d
PlanMaker on OpenBSD
Post by jon-d » Thu Sep 09, 2004 6:47 pm
Hello Martin:
I got the trial version of PlanMaker and installed it in OpenBSD's /emul/linux directory.
I started it by typing $ /emul/linux/planmakertrial/planmaker
It ran just fine. I loaded several *.xls spreadsheets and they rendered just fine. All the steps above used for configuring Linux emulation work for PlanMaker too.
Post by martin-k » Sun Sep 12, 2004 4:07 pm
Thank you for checking this. I have now updated the PlanMaker pages as well accordingly.
jon-d
TextMaker in OpenBSD 3.6
Post by jon-d » Tue Mar 22, 2005 7:02 pm
TextMaker is working fine in OpenBSD 3.6. The same instructions (above) apply.
Post by martin-k » Tue Mar 22, 2005 7:35 pm
Thank you for the update. Web pages are updated now.
Return to “TextMaker 2002 for Linux and FreeBSD”
