How to install TM from rpm in DSL?
Help for TextMaker 2002 for Linux and FreeBSD
runbei
Post by runbei » Fri Jun 16, 2006 6:06 am
Can someone tell me how to install TextMaker from an rpm file into Damn Small Linux? (I'm a Linux noob.) I have a registered copy that I got with commercial SuSE Linux 10.
Thanks.
George Beinhorn
Mountain View, CA
http://www.writeremedy.com
Tobias-L
Post by Tobias-L » Mon Jun 19, 2006 9:01 am
The rpm from SUSE Linux will not work on DSL. Please download the tgz file from our server and unpack it.
Code: Select all
tar xzvf textmakertrial.tgz
cd textmakertrial
./tml
Tobias Leißner
runbei
Use my existing serial #?
Post by runbei » Sat Jun 24, 2006 8:16 pm
Can I use my TM serial number for SuSE to register the downloaded trial file? (I also own registered TM for WinXP.) - Thanks.
George Beinhorn
Mountain View, CA
Tobias-L
Post by Tobias-L » Mon Jun 26, 2006 9:12 am
You do not need to register the trial version, only full versions.
You only have a serial for TextMaker 2006 for Windows. This serial will not work for TextMaker 2002 for Linux. You have to purchase a separate license for it.
Tobias Leißner
Return to “TextMaker 2002 for Linux and FreeBSD”
