Shortcut for all users [SOLVED]
medeiros
Post by medeiros »
Dear friends,
The official version of SM Office 2018 don't generate shortcuts of programs (textmaker, planmaker, etc..) for all users of computer, only for user with install permission... This small problem already into beta version... and the programs don't be showed on start button.
For grant access the programs is necessary found the installation directory and create a shortcut into desktop area for each user...
TIA
Medeiros
msteinborn
Post by msteinborn »
As a quick workaround: Try installing from cmd.exe:
ofw2018_64.msi ALLUSERS=1
That should do it (after uninstalling the wrong installation).
msteinborn
Re: Shortcut for all users
It seems that I have to add that cmd.exe has to be run with administrator's privileges.
medeiros
Post by medeiros »
Thank you for trick. I'm very happy with SoftMaker. Congratulations.
