Page not aligned to center when in fullscreen
Post your questions, bug reports and suggestions here for TextMaker 2018 for Windows.
R3gi
Post by R3gi » Mon Nov 06, 2017 11:17 am
Hi,
I've just started using TextMaker 2018 Beta 912.1023 x64 on Windows 7 HP SP1 x64.
When I open a new empty document, the page is aligned to center, but once I maximize the window (the window width is greater than 2× page width), the page is positioned at the left side of the window. I consider this as a bug, but it's so obvious that I'm not sure if it's really a bug or there's something incorrectly set.
Is there a way to center a page in the UI when the window is maximized/wide?
Re: Page not aligned to center when in fullscreen
Post by martin-k » Mon Nov 06, 2017 12:26 pm
You can uncheck "View pages side-by-side" in the Options dialog of TextMaker.
R3gi
Post by R3gi » Mon Nov 06, 2017 4:19 pm
Ah, that's it, I missed it. I wouldn't expect this enabled as default. Thank you very much! Solved.
Return to “Beta: TextMaker 2018 for Windows”
