Embedded Fonts Do Not Save in TextMaker 2018
Post your questions, bug reports and suggestions here for TextMaker 2018 for Windows.
Ian Wood
Post by Ian Wood » Sun Oct 29, 2017 5:50 pm
I am using beta 909.1005 64 bit TextMaker 2018 on Windows 10.
When I open a file created in Word, with embedded fonts, then save the file, the embedded font directive is discarded with no warning. It is not acceptable for an application to change vital file attributes the user has set, and especially not without warning.
This isn't when the file is being exported to PDF, ti is when the file is being saved as a .DOC format file.
If I had created a new file in TextMaker, then I can see how I might need to set it up to save as I want, but when an existing file is opened, TextMaker should preserve the existing attributes. The user should not have to tell it to set things which are already set up in the file.
Re: Embedded Fonts Do Not Save in TextMaker 2018
Post by sven-l » Mon Nov 06, 2017 2:16 pm
Could you please attach a sample file (with that embedded font) or send it to forum(at)softmaker.de? Thank you!
Return to “Beta: TextMaker 2018 for Windows”
