Suggestions for TextMaker
Post here those questions, bug reports and suggestions for SoftMaker Office 2018 for Windows that do not fit in any of the application-specific subforums.
Petar_MK
Post by Petar_MK » Mon Oct 09, 2017 2:27 pm
So far, so good. The software is stable, no problems at all. I have some suggestions about Textmaker:
1. Is it possible under “Properties > Statistics” to rename “Keystrokes” into “Characters with Spaces” and “Characters” into “Characters without spaces”?
2. Could you add printing “Selected text” in “Print” dialog window?
3. I don’t consider this as a bug, but it would be nice if you can change it: Before converting a picture into a object frame to reposition it freely on the page, I add a caption to it. But, after converting it, caption is not moved together with the picture. Even if I add a new caption to converted picture.
Dell Inspiron 7559 i7
Intel Core i7-6700HQ (3.50 GHz, 6M )
16GB Dual Channel DDR3L 1600MHz (8GBx2)
1TB HDD + 128 GB SSD Hard drive
UHD (3840 x 2160) Truelife LED- Backlit Touch Display
NVIDIA GeForce GTX 960M 4GB GDDR5
Windows 10 x64
Re: Suggestions for TextMaker
Post by Jossi » Mon Oct 09, 2017 5:35 pm
Petar_MK wrote:Before converting a picture into a object frame to reposition it freely on the page, I add a caption to it. But, after converting it, caption is not moved together with the picture. Even if I add a new caption to converted picture.
The caption is in a separate text frame. When you group the picture frame and the text frame they can be moved together, but I agree with your suggestion that they should be grouped automatically by default.
Petar_MK
Post by Petar_MK » Mon Oct 09, 2017 7:02 pm
Yes, I know that text is in separate text box, but they have to be grouped as in InDesign.
Windows 10 x64
TrueMe
Post by TrueMe » Mon Oct 23, 2017 7:44 pm
I concur with Item 1. It is a little confusing. A [CR] is technically a keystroke, but those are not counted.
Post by sven-l » Fri Oct 27, 2017 5:18 pm
I will refer that suggestion to the product management.
Return to “Beta: SoftMaker Office 2018 for Windows (General)”
