FlexiPDF User-defined stamps
Post your questions, bug reports and suggestions here for FlexiPDF 2017
charles338
Post by charles338 » Thu Dec 14, 2017 8:39 am
I am new using the software but love the fact that there are stamps to mark PDF files with. An instance, I get my gas bill via my email account as a PDF file. I can use my User-defined stamp "Paid In Full" to mark it so and print out a copy to keep on file. Could someone please give a step by step instruction to accomplish this. I can insert it into the file but when I print out a copy nothing shows except the original file. Also is it possible to make User-defined stamp that will input todays date and also have a line for receipt numbers? Thank you for any help any one can give me. Charles
Re: FlexiPDF User-defined stamps
Post by sven-l » Mon Dec 18, 2017 4:19 pm
Does it work better with a built-in stamp? I tried it with some different stamps and they all were visible after printing the PDF.
charles338
Post by charles338 » Mon Dec 18, 2017 10:59 pm
I made my own User-defined stamp "Paid In Full". I took a bill that I receive through an email as an attached PDF file and opened it with FlexiPDF. I then used my User-defined stamp and pasted it into the PDF file. I can see it "Paid In Full" but if I print it out, the User-defined stamp is not visible. If I save the file and then print it the User-defined stamp does not show up in the print out. As a matter of fact none of the Stamps show up after being inserted in a PDF file when they are printed. They all show up in the file, but they do not show up in/on the print out!
Post by sven-l » Thu Dec 21, 2017 11:31 am
Could you please send the user defined stamp and a sample PDF file to forum(at)softmaker.com or attach the files here? Thank you!
charles338
Post by charles338 » Fri Dec 22, 2017 2:12 am
Thanks Sven,
I am sending the files you requested! Thanks :D
Charles
Paid In Full.pdf
(20.82 KiB) Downloaded 25 times
SimplyEnergyGas_2017_12_22 [226794].pdf
(154.97 KiB) Downloaded 44 times
Post by sven-l » Fri Dec 22, 2017 3:27 pm
Thank you! I will refer this issue to the developers.
Return to “FlexiPDF 2017”
