Installing FO 2016 on Ubuntu 14.04 x64
Post here those questions, bug reports and suggestions for SoftMaker FreeOffice 2016 for Linux that do not fit in any of the application-specific subforums.
zanzibear
Post by zanzibear » Wed May 04, 2016 8:22 pm
When installiing FO 2016 on Ubuntu 14.4., installation responds with error "glib1-mesa-glx:i386" missing.
Some search points to missing libraries, that can be easyl installed:
Less than 14.04.3 64bits:
sudo apt-get install libc6:i386 libgl1-mesa-dri-lts-utopic:i386 libgl1-mesa-glx-lts-utopic:i386
At least 14.04.3 64bits:
sudo apt-get install libc6:i386 libgl1-mesa-dri-lts-vivid:i386 libgl1-mesa-glx-lts-vivid:i386
Might be a bug in FO install, but anyway, this works perfectly.
Credits to resolution on this askubuntu.com solution:
http://askubuntu.com/questions/588024/s ... untu-64bit
Re: Installing FO 2016 on Ubuntu 14.04 x64
Post by sven-l » Fri May 06, 2016 9:53 am
Please make sure to use
Code: Select all
sudo apt-get install -f
after the installation via dpkg in the terminal:
http://www.freeoffice.com/en/tips-and-tricks-linux
Return to “SoftMaker FreeOffice 2016 for Linux (General)”
