xlsx as default file format
Post your questions, bug reports and suggestions here for FreeOffice PlanMaker 2016 for Windows
Nooboras
Post by Nooboras » Thu May 04, 2017 12:59 pm
Hello,
In the information tab it says that you can set xlsx as default file format but when i look at Tools > Options > Files tab there are 4 options : PlanMaker , PlanMaker 2012 , Excel 97-2003 and Excel 5.0/7.0.
Also , is there a way to rotate text in a textbox? The only thing i found is a rotation by 90 degrees increment , is there a way to do it by less than that?
Thanks in advance for your time.
Re: xlsx as default file format
Post by sven-l » Thu May 04, 2017 2:09 pm
The .xlsx file format is only available in SoftMaker Office but not in FreeOffice.
Currently there is no other way to rotate text in a textbox than in 90 degree increments.
Return to “FreeOffice PlanMaker 2016 for Windows”
