PlanMaker Crashing
Post your questions, bug reports and suggestions here for FreeOffice PlanMaker 2016 for Windows
georgeschulze
PlanMaker Crashing
Post by georgeschulze » Tue Dec 20, 2016 7:45 pm
After I make an update to the attached file and do not save the changes , after 5 - 10 mins PlanMaker crashes.
Could you please look into this for me?
Thank you very much.
george schulze
george.schulzr@gmail.com
AL Membership Request Log for SoftMaker..xls
(124.5 KiB) Downloaded 90 times
togononmj
Re: PlanMaker Crashing
Post by togononmj » Thu Dec 22, 2016 9:34 am
Hi georgeschulze,
I have downloaded the file and opened it on PlanMaker and made changes without saving, and it seems to be fine from my end.
Could you please advise what are the steps you are doing so I could replicate the issue?
Also did you receive an error message from PlanMaker after it crashes?
Please advise as it would help me diagnose the problem.
Thanks,
togononmj
georgeschulze
Post by georgeschulze » Thu Dec 22, 2016 5:44 pm
OK thanks.
I just tested again and it crashed again.
I added a line to spreadsheet. Did not save. Left Planmaker.
AFter about 2 - 5 mins I received a message that Planmaker crashed.
I captured the message that is displayed.
I attached the file with the error message.
georgeschulze
Post by georgeschulze » Thu Dec 22, 2016 5:47 pm
Sorry but that file came out bad. I will try again to capture.
Post by martin-k » Thu Dec 22, 2016 6:42 pm
And when you restart, does PlanMaker offer to send a crash report?
georgeschulze
Post by georgeschulze » Thu Dec 22, 2016 7:15 pm
Yes, I receive a message that asks if I want to send a report to PlanMaker. I tried but looks like I had a MAPI error. Not sure what that means.
There was no status info in the message.
It crashed again after I made some changes but did not save the changes.
I attached the two error messages I receive.
I am attaching the file again that I used. Please use it as the original I sent was a subset of this file.
AL Membership Request Log.xls
(464.5 KiB) Downloaded 141 times
Post by martin-k » Thu Dec 22, 2016 7:18 pm
That's too bad that your e-mail is not configured to allow sending a crash report.
Could you check your hard disk (probably the temp folder %temp%) for the file pmcrashreport.zip ? This would be the crash report that we need.
georgeschulze
Post by georgeschulze » Thu Dec 22, 2016 8:55 pm
I cannot find that file (pmcrashreport.zip). I checked entire "C" drive.
Do you know how to configure MAPI to send the report?
That look like only hope now.
I have OUTLOOK and GMAIL for email.
Post by martin-k » Thu Dec 22, 2016 9:03 pm
1. Start the Windows tool "Default Progrrams". I describe what I see on Windows 7:
2. From the list of menu items choose "Set your default programs".
3. In the list of applications that appears now, choose "Outlook".
4. Click on "Choose defaults for this program"
5. Near the bottom there should be an entry about MAPI. Activate the checkbox.
georgeschulze
Post by georgeschulze » Sat Dec 24, 2016 4:55 pm
OK I made the changes as outlined...thanks very much.
Planmaker has not crashed since however. I will continue to monitor and update you as
time goes on.
Thanks and have a great holiday season.
georgeschulze
Post by georgeschulze » Wed Jan 04, 2017 6:40 pm
OK no problems since 12/24 so I think it best to close this out and I will reopen if problem occurs in future.
Return to “FreeOffice PlanMaker 2016 for Windows”
