Center Image
Post here those questions, bug reports and suggestions for SoftMaker FreeOffice 2016 for Windows that do not fit in any of the application-specific subforums.
Suono & Computer
Center Image
Post by Suono & Computer » Wed Sep 27, 2017 9:58 am
Hello, I wonder if it is possible to insert the function to center an inserted image on the sheet. Thank you.
https://www.youtube.com/channel/UCt281paunNVexCa23zB8cow?view_as=subscriber
Re: Center Image
Post by martin-k » Wed Sep 27, 2017 10:12 am
TextMaker? PlanMaker? Presentations?
Suono & Computer
Re: Center Image
Post by Suono & Computer » Tue Oct 03, 2017 9:26 pm
I apologize, I asked the question in the wrong section. The question is addressed to Text Maker free version. I tried in the image properties menu to select "centered" horizontally, but the image does not center and I have to move it manually with the mouse.
Re: Center Image
Post by Jossi » Wed Oct 04, 2017 1:44 pm
Same here with picture frames in TextMaker Professional 2016. When you change the horizontal position in Picture Properties to "Centered", only the value in "Offset" changes, the picture stays where it is. You have to change "Offset" manually to "0 cm" to actually center the picture. I daresay this is a bit counterintuitive.
Suono & Computer
Re: Center Image
Post by Suono & Computer » Thu Oct 05, 2017 8:19 am
Here, thank you very much!
Return to “SoftMaker FreeOffice 2016 for Windows (General)”
