wiped file access history
Post here those questions, bug reports and suggestions for SoftMaker FreeOffice 2016 for Windows that do not fit in any of the application-specific subforums.
techchat
Post by techchat » Mon Aug 15, 2016 12:17 am
Where does freeoffice 2016 store quick access recent files in the file menu please? At the moment they are deleted every time I run Ccleaner so I lose my file access history. :(
Re: wiped file access history
Post by sven-l » Mon Aug 15, 2016 11:10 am
The recent file history is saved in C:\Users\YOUR NAME\Documents\SoftMaker\Settings\tmwfoconfig.ini (or pmwfoconfig.ini or prwfoconfig.ini, for PlanMaker and Presentations, respectively).
techchat
Post by techchat » Mon Aug 15, 2016 12:17 pm
Thank you! I have exluded the SETTING folder from ccleaner/option/exclude and it works. :D
anewuser
Post by anewuser » Mon Aug 29, 2016 9:06 pm
Alternatively, you can "pin" (bookmark) most frequently used documments on the start menu (win7)
Return to “SoftMaker FreeOffice 2016 for Windows (General)”
