Show All Open Files in Windows10
Post here those questions, bug reports and suggestions for SoftMaker FreeOffice 2016 for Windows that do not fit in any of the application-specific subforums.
KevanB
Post by KevanB » Thu Jul 28, 2016 12:06 am
When using Alt-Tab to switch to another application, I can only see the current planmaker file, not all open files. In the paid version there are extra options under Tools\Options\General. Have these been left out of FreeOffice?
Re: Show All Open Files in Windows10
Post by sven-l » Thu Jul 28, 2016 9:35 am
Alt+Tab cycles between applications, not between documents. SoftMaker FreeOffice is an MDI application, so you can switch through documents either with its Window menu or with Ctrl+F6.
SoftMaker Office adds document tabs which makes the process much smoother.
Return to “SoftMaker FreeOffice 2016 for Windows (General)”
