Macro capability?
Post your questions, bug reports and suggestions here for PlanMaker 2016 for Linux.
jfb1617
Macro capability?
Post by jfb1617 » Sun Dec 13, 2015 11:53 pm
Does PlanMaker for Linux have macro capability. If so what languages are supported?
Thanks, Jim
Re: Macro capability?
Post by sven-l » Mon Dec 21, 2015 3:49 pm
No, macros are not supported under Linux.
Michael Uplawski
Post by Michael Uplawski » Tue Dec 22, 2015 7:08 am
See also: “Any scripting support on Linux?
Good morning.
As PlanMaker now uses a compressed xml-based file-format (you can unzip it), I am myself interested in writing scripts that munch the data outside of PlanMaker. As you can have a tool-button for such a routine in the task-bar, it would be possible to call the script from PlanMaker and have the altered file loaded, after execution.
The binary file-format of *.pmdx files is known under Linux as “Microsoft OOXML”, meaning that it is somewhat “standardized” (by someone, somewhere, in a defined context and for the people who care), there should be information and maybe examples on the net, already. The schema is indicated as: http://schemas.openxmlformats.org/sprea ... /2006/main
I do not (yet) know, how much of all that I will myself have the nerve to explore and exploit, but to resume, you can do a lot with XSLT or the libraries for XML-handling that are available for most current programming languages.
Do not expect an integrated scripting interface any time soon.
Michael
Last edited by Michael Uplawski on Sat Aug 27, 2016 10:56 am, edited 1 time in total.
People should go where they are not supposed to go, say what they are not supposed to say and stay, when they are told to leave.” (Howard Zinn)
Michael Uplawski
Post by Michael Uplawski » Sun Dec 27, 2015 11:12 am
Michael Uplawski wrote:The binary file-format of *.pmdx files is known under Linux as “Microsoft OOXML”, meaning that it is somewhat “standardized” (by someone, somewhere, in a defined context and for the people who care), there should be information and maybe examples on the net, already. The schema is indicated as: http://schemas.openxmlformats.org/sprea ... /2006/main
Among other sources, many of which use the Microsoft SDK, I found some pages which explain the file-format in detail. Here is one which talks a lot about date-formats and manipulates them inside the xml:
http://openxmldeveloper.org/discussions ... t/242.aspx
This here tells why OOXML was a bad choice (and the origin of some future discussions in the SoftMaker-forum):
http://www.linuxveda.com/2014/11/29/nev ... rd-format/
Edit: Unfortunately SoftMaker has added a few definitions to their file-formats which render them incompatible even where Mocrosoft OOXML would normally be recognized. For someone who bases his development work on the so-called “standard”, this is a major inconvenience.
And... Edit: ODS rules.
Return to “PlanMaker 2016 for Linux”
