Christmas card list - mail merger problem
Post your questions, bug reports and suggestions here for TextMaker 2016 for Linux.
divaddrof
Post by divaddrof » Fri Dec 15, 2017 9:20 pm
Hi
I had to print some Christmas names and addresses - from various word documents, sent by my daughter in the US.
So I tried using the excel sheet as the source - but couldn't get it to work. Maybe my fault, see below.
I exported the excel sheet (from Plankamer) as a csv file - and use that OK - but I had to fix the file - the xls file had the first row blank (instead of column names) - this might have caused the previous problem.
When I selected a range to print with Print Merge - it worked fine,
But when I selected a particular record with the Properties dialog and then tried to merge print just the Selected record - it tried to print the whole list instead of the one I selected. Is there another way to select a record?
The text of one record had a name with a cedilla under the c and this did not translate to the different linux font.
So far - not bad.
Printed and merged greetings insert from csv
Printed and merged address labels
Looks good!
Hope this helps
David
Re: Christmas card list - mail merger problem
Post by sven-l » Tue Dec 19, 2017 11:09 am
Please save the Excel file as .dbf file (dBase). This file format is supported by TextMaker for databases.
Return to “TextMaker 2016 for Linux”
