Segmentation fault
Post your questions, bug reports and suggestions here for TextMaker 2016 for Linux.
vitor895
Segmentation fault
Post by vitor895 » Sun Sep 11, 2016 10:58 pm
Hi
When I try to open a2-2-ano-resolvido.doc I get a segmentation fault
I have Arch Linux and my laptop is Intel and I use SoftMaker Office (version 757.0510 Student Version) installed from https://aur4.archlinux.org/packages/sof ... -2016-bin/
The hole system is up to date, kernel 4.7.2-1-ARCH #1 SMP PREEMPT Sat Aug 20 23:02:56 CEST 2016 x86_64 GNU/Linux
[vitor@vitor-note Downloads]$ textmaker16 a2-2-ano-resolvido.doc
/usr/bin/textmaker16: line 4: 7303 Segmentation fault (core dumped)/opt/smoffice2016/textmaker "$@"
Thank you
(746.5 KiB) Downloaded 123 times
Michael Uplawski
Re: Segmentation fault
Post by Michael Uplawski » Wed Sep 21, 2016 8:50 pm
No problems with Softmaker16free 758. I can scroll through all 11 pages of trigonometry. Here is a Pi for you: π (U+03C0), a Phi: φ (U+03C6) and Alpha: α (U+03B1).
People should go where they are not supposed to go, say what they are not supposed to say and stay, when they are told to leave.” (Howard Zinn)
vitor895
Post by vitor895 » Mon Oct 03, 2016 12:14 am
I tested this file with FreeOffice and SoftMaker Office 2016 (new version 761) and yet a segmentation fault
vitor895
Post by vitor895 » Fri Oct 07, 2016 12:21 am
It's a very hard bug because it crashes randomly. I'm using modesetting graphics driver and kernel parameter intel_idle.max_cstate=1
No other software crashes in my system
[vitor@vitor-note Downloads]$ textmaker16 a2-2-ano-resolvido.doc --debug
Gtk-Message: (for origin information, set GTK_DEBUG): failed to retrieve property `gtk-primary-button-warps-slider' of type `gboolean' from rc file value "((GString*) 0x15068a0)" of type `gboolean'
/usr/bin/textmaker16: line 4: 6058 Falha de segmentação (imagem do núcleo gravada)/opt/smoffice2016/textmaker "$@"
Gtk-Message: (for origin information, set GTK_DEBUG): failed to retrieve property `gtk-primary-button-warps-slider' of type `gboolean' from rc file value "((GString*) 0x26188a0)" of type `gboolean'
*** Error in `/opt/smoffice2016/textmaker': free(): invalid next size (fast): 0x0b50c218 ***
======= Backtrace: =========
/usr/lib32/libc.so.6(+0x6815a)[0xf6d6a15a]
/usr/lib32/libc.so.6(+0x6ed07)[0xf6d70d07]
/usr/lib32/libc.so.6(+0x6f4d6)[0xf6d714d6]
/opt/smoffice2016/textmaker[0x878099a]
/opt/smoffice2016/textmaker[0x878c62b]
/opt/smoffice2016/textmaker[0x8784e53]
/opt/smoffice2016/textmaker[0x8784f2d]
/opt/smoffice2016/textmaker[0x878525b]
/opt/smoffice2016/textmaker[0x8a95141]
/opt/smoffice2016/textmaker[0x8a95c9b]
/opt/smoffice2016/textmaker[0x87c6417]
/opt/smoffice2016/textmaker[0x87c5e76]
/opt/smoffice2016/textmaker[0x87c6595]
/opt/smoffice2016/textmaker[0x87c6043]
/opt/smoffice2016/textmaker[0x87c6242]
/opt/smoffice2016/textmaker[0x87c63ab]
/opt/smoffice2016/textmaker[0x8a9885e]
/opt/smoffice2016/textmaker[0x8a98d78]
/opt/smoffice2016/textmaker[0x8a92910]
/opt/smoffice2016/textmaker[0x8a92643]
/opt/smoffice2016/textmaker[0x8a9bb96]
/opt/smoffice2016/textmaker[0x84df67f]
/opt/smoffice2016/textmaker[0x84e0aaa]
/opt/smoffice2016/textmaker[0x84dd574]
/opt/smoffice2016/textmaker[0x84ee4e4]
/opt/smoffice2016/textmaker[0x84f2905]
/opt/smoffice2016/textmaker[0x84f5391]
/opt/smoffice2016/textmaker[0x84e1619]
/opt/smoffice2016/textmaker[0x84e2613]
/opt/smoffice2016/textmaker[0x84e42b7]
/opt/smoffice2016/textmaker[0x84e56b9]
/opt/smoffice2016/textmaker[0x84e60bd]
/opt/smoffice2016/textmaker[0x8500622]
/opt/smoffice2016/textmaker[0x8504b59]
/opt/smoffice2016/textmaker[0x8359f9b]
/opt/smoffice2016/textmaker[0x831fdad]
/opt/smoffice2016/textmaker[0x8ab3e8b]
/opt/smoffice2016/textmaker[0x8ab5a62]
/opt/smoffice2016/textmaker[0x831f983]
/opt/smoffice2016/textmaker[0x8ac4e0a]
/opt/smoffice2016/textmaker[0x85dccfe]
/opt/smoffice2016/textmaker[0x8ab3e40]
/opt/smoffice2016/textmaker[0x8ab3fd4]
/opt/smoffice2016/textmaker[0x8abf688]
/opt/smoffice2016/textmaker[0x8abf7f7]
/opt/smoffice2016/textmaker[0x85db0f6]
/opt/smoffice2016/textmaker[0x8acb09c]
/usr/lib32/libc.so.6(__libc_start_main+0xf6)[0xf6d1a196]
======= Memory map: ========
08048000-08eb7000 r-xp 00000000 08:03 2101877 /opt/smoffice2016/textmaker
08eb7000-08eb8000 r-xp 00e6f000 08:03 2101877 /opt/smoffice2016/textmaker
08eb8000-08f72000 rwxp 00e70000 08:03 2101877 /opt/smoffice2016/textmaker
08f72000-09016000 rwxp 00000000 00:00 0
0a8ca000-0d6dc000 rwxp 00000000 00:00 0 [heap]
f38b5000-f3b00000 rwxp 00000000 00:00 0
f3b00000-f3b49000 rwxp 00000000 00:00 0
f3b49000-f3c00000 ---p 00000000 00:00 0
f3c00000-f3c21000 rwxp 00000000 00:00 0
f3c21000-f3d00000 ---p 00000000 00:00 0
f3d00000-f3ded000 rwxp 00000000 00:00 0
f3ded000-f3e00000 ---p 00000000 00:00 0
f3ede000-f3ef2000 rwxs 101c32000 00:06 35 /dev/dri/card0
f3ef2000-f3ef3000 ---p 00000000 00:00 0
f3ef3000-f4821000 rwxp 00000000 00:00 0
f4821000-f4921000 rwxs 1006c2000 00:06 35 /dev/dri/card0
f4926000-f4927000 rwxp 00000000 00:00 0
f4927000-f4928000 rwxs 00000000 00:05 118585 /drm mm object (deleted)
f4928000-f4929000 rwxs 00000000 00:05 118584 /drm mm object (deleted)
f4929000-f492a000 rwxs 00000000 00:05 118583 /drm mm object (deleted)
f492a000-f492b000 rwxs 00000000 00:05 118582 /drm mm object (deleted)
f492b000-f492c000 rwxs 00000000 00:05 118581 /drm mm object (deleted)
f492c000-f492d000 rwxs 00000000 00:05 118579 /drm mm object (deleted)
f492d000-f492e000 rwxs 00000000 00:05 118578 /drm mm object (deleted)
f492e000-f492f000 rwxs 00000000 00:05 118577 /drm mm object (deleted)
f492f000-f4930000 rwxs 00000000 00:05 118576 /drm mm object (deleted)
f4930000-f4931000 rwxs 00000000 00:05 118575 /drm mm object (deleted)
f4931000-f4932000 rwxs 00000000 00:05 118574 /drm mm object (deleted)
f4932000-f4933000 rwxs 00000000 00:05 118573 /drm mm object (deleted)
f4933000-f4934000 rwxs 00000000 00:05 118572 /drm mm object (deleted)
f4934000-f4935000 rwxs 00000000 00:05 118571 /drm mm object (deleted)
f4935000-f4936000 rwxs 00000000 00:05 118570 /drm mm object (deleted)
f4936000-f4937000 rwxs 00000000 00:05 118569 /drm mm object (deleted)
f4937000-f4938000 rwxs 00000000 00:05 118568 /drm mm object (deleted)
f4938000-f4939000 rwxs 00000000 00:05 118567 /drm mm object (deleted)
f4939000-f493a000 rwxs 00000000 00:05 118566 /drm mm object (deleted)
f493a000-f493b000 rwxs 00000000 00:05 118565 /drm mm object (deleted)
f493b000-f493c000 rwxs 00000000 00:05 118564 /drm mm object (deleted)
f493c000-f493d000 rwxs 00000000 00:05 118563 /drm mm object (deleted)
f493d000-f493e000 rwxs 00000000 00:05 118562 /drm mm object (deleted)
f493e000-f493f000 rwxs 00000000 00:05 118561 /drm mm object (deleted)
f493f000-f4940000 rwxs 00000000 00:05 118560 /drm mm object (deleted)
f4940000-f4941000 rwxs 00000000 00:05 118559 /drm mm object (deleted)
f4941000-f4942000 rwxs 00000000 00:05 118558 /drm mm object (deleted)
f4942000-f4943000 rwxs 00000000 00:05 118557 /drm mm object (deleted)
f4943000-f4944000 rwxs 00000000 00:05 118556 /drm mm object (deleted)
f4944000-f4945000 rwxs 00000000 00:05 118555 /drm mm object (deleted)
f4945000-f4946000 rwxs 00000000 00:05 118554 /drm mm object (deleted)
f4946000-f4947000 rwxs 00000000 00:05 118553 /drm mm object (deleted)
f4947000-f4948000 rwxs 00000000 00:05 118552 /drm mm object (deleted)
f4948000-f4949000 rwxs 00000000 00:05 118551 /drm mm object (deleted)
f4949000-f494a000 rwxs 00000000 00:05 118550 /drm mm object (deleted)
f494a000-f494b000 rwxs 00000000 00:05 118549 /drm mm object (deleted)
f494b000-f494c000 rwxs 00000000 00:05 118548 /drm mm object (deleted)
f494c000-f494d000 rwxs 00000000 00:05 118547 /drm mm object (deleted)
f494d000-f494e000 rwxs 00000000 00:05 118546 /drm mm object (deleted)
f494e000-f494f000 rwxs 00000000 00:05 118545 /drm mm object (deleted)
f494f000-f4950000 rwxs 00000000 00:05 118544 /drm mm object (deleted)
f4950000-f4951000 rwxs 00000000 00:05 118543 /drm mm object (deleted)
f4951000-f4952000 rwxs 00000000 00:05 118542 /drm mm object (deleted)
f4952000-f4953000 rwxs 00000000 00:05 118541 /drm mm object (deleted)
f4953000-f4954000 rwxs 00000000 00:05 118540 /drm mm object (deleted)
f4954000-f4955000 rwxs 00000000 00:05 118539 /drm mm object (deleted)
f4955000-f4956000 rwxs 00000000 00:05 118538 /drm mm object (deleted)
f4956000-f4957000 rwxs 00000000 00:05 118537 /drm mm object (deleted)
f4957000-f4958000 rwxs 00000000 00:05 118536 /drm mm object (deleted)
f4958000-f4959000 rwxs 00000000 00:05 118535 /drm mm object (deleted)
f4959000-f495a000 rwxs 00000000 00:05 118534 /drm mm object (deleted)
f495a000-f495b000 rwxs 00000000 00:05 118533 /drm mm object (deleted)
f495b000-f495c000 rwxs 00000000 00:05 118532 /drm mm object (deleted)
f495c000-f495d000 rwxs 00000000 00:05 118531 /drm mm object (deleted)
f495d000-f495e000 rwxs 00000000 00:05 118530 /drm mm object (deleted)
f495e000-f495f000 rwxs 00000000 00:05 118529 /drm mm object (deleted)
f495f000-f4960000 rwxs 00000000 00:05 118528 /drm mm object (deleted)
f4960000-f4961000 rwxs 00000000 00:05 118527 /drm mm object (deleted)
f4961000-f4962000 rwxs 00000000 00:05 118526 /drm mm object (deleted)
f4962000-f4963000 rwxs 00000000 00:05 118525 /drm mm object (deleted)
f4963000-f4964000 rwxs 00000000 00:05 118524 /drm mm object (deleted)
f4964000-f4965000 rwxs 00000000 00:05 118523 /drm mm object (deleted)
f4965000-f4966000 rwxs 00000000 00:05 118522 /drm mm object (deleted)
f4966000-f4967000 rwxs 00000000 00:05 118521 /drm mm object (deleted)
f4967000-f4968000 rwxs 00000000 00:05 118520 /drm mm object (deleted)
f4968000-f4969000 rwxs 00000000 00:05 118519 /drm mm object (deleted)
f4969000-f496a000 rwxs 00000000 00:05 118518 /drm mm object (deleted)
f496a000-f496b000 rwxs 00000000 00:05 118517 /drm mm object (deleted)
f496b000-f496c000 rwxs 00000000 00:05 118516 /drm mm object (deleted)
f496c000-f496d000 rwxs 00000000 00:05 118515 /drm mm object (deleted)
f496d000-f496e000 rwxs 00000000 00:05 118514 /drm mm object (deleted)
f496e000-f496f000 rwxs 00000000 00:05 118513 /drm mm object (deleted)
f496f000-f4970000 rwxs 00000000 00:05 118512 /drm mm object (deleted)
f4970000-f4971000 rwxs 00000000 00:05 118511 /drm mm object (deleted)
f4971000-f4972000 rwxs 00000000 00:05 118510 /drm mm object (deleted)
f4972000-f4973000 rwxs 00000000 00:05 118509 /drm mm object (deleted)
f4973000-f499b000 rwxs 101c0a000 00:06 35 /dev/dri/card0
f499b000-f49a5000 rwxs 10062d000 00:06 35 /dev/dri/card0
f49a5000-f49c1000 rwxs 100611000 00:06 35 /dev/dri/card0
f49c1000-f49c2000 rwxs 00000000 00:05 118505 /drm mm object (deleted)
f49c2000-f49c3000 rwxs 00000000 00:05 118504 /drm mm object (deleted)
f49c3000-f49c4000 rwxs 00000000 00:05 118503 /drm mm object (deleted)
f49c4000-f49c5000 rwxs 00000000 00:05 118502 /drm mm object (deleted)
f49c5000-f49c6000 rwxs 00000000 00:05 118501 /drm mm object (deleted)
f49c6000-f49c7000 rwxs 00000000 00:05 118500 /drm mm object (deleted)
f49c7000-f49c8000 rwxs 00000000 00:05 118499 /drm mm object (deleted)
f49c8000-f49c9000 rwxs 00000000 00:05 118498 /drm mm object (deleted)
f49c9000-f49ca000 rwxs 00000000 00:05 118497 /drm mm object (deleted)
f49ca000-f49cb000 rwxs 00000000 00:05 118496 /drm mm object (deleted)
f49cb000-f49cc000 rwxs 00000000 00:05 118495 /drm mm object (deleted)
f49cc000-f49cd000 rwxs 00000000 00:05 118494 /drm mm object (deleted)
f49cd000-f49ce000 rwxs 00000000 00:05 118493 /drm mm object (deleted)
f49ce000-f49cf000 rwxs 00000000 00:05 118492 /drm mm object (deleted)
f49cf000-f49d0000 rwxs 00000000 00:05 118491 /drm mm object (deleted)
f49d0000-f49d1000 rwxs 00000000 00:05 118490 /drm mm object (deleted)
f49d1000-f49d2000 rwxs 00000000 00:05 118489 /drm mm object (deleted)
f49d2000-f49d3000 rwxs 00000000 00:05 118488 /drm mm object (deleted)
f49d3000-f49d4000 rwxs 00000000 00:05 118487 /drm mm object (deleted)
f49d4000-f49d5000 rwxs 00000000 00:05 118486 /drm mm object (deleted)
f49d5000-f49d6000 rwxs 00000000 00:05 118485 /drm mm object (deleted)
f49d6000-f49d7000 rwxs 00000000 00:05 118484 /drm mm object (deleted)
f49d7000-f49d8000 rwxs 00000000 00:05 118483 /drm mm object (deleted)
f49d8000-f49d9000 rwxs 00000000 00:05 118482 /drm mm object (deleted)
f49d9000-f49da000 rwxs 00000000 00:05 118481 /drm mm object (deleted)
f49da000-f49db000 rwxs 00000000 00:05 118480 /drm mm object (deleted)
f49db000-f49dc000 rwxs 00000000 00:05 118479 /drm mm object (deleted)
f49dc000-f49dd000 rwxs 00000000 00:05 118478 /drm mm object (deleted)
f49dd000-f49de000 rwxs 00000000 00:05 118477 /drm mm object (deleted)
f49de000-f49df000 rwxs 00000000 00:05 118476 /drm mm object (deleted)
f49df000-f49e0000 rwxs 00000000 00:05 118475 /drm mm object (deleted)
f49e0000-f49e1000 rwxs 00000000 00:05 118474 /drm mm object (deleted)
f49e1000-f49e2000 rwxs 00000000 00:05 118473 /drm mm object (deleted)
f49e2000-f49e3000 rwxs 00000000 00:05 118472 /drm mm object (deleted)
f49e3000-f49e4000 rwxs 00000000 00:05 118471 /drm mm object (deleted)
f49e4000-f49e5000 rwxs 00000000 00:05 118470 /drm mm object (deleted)
f49e5000-f49e6000 rwxs 00000000 00:05 118469 /drm mm object (deleted)
f49e6000-f49e7000 rwxs 00000000 00:05 118468 /drm mm object (deleted)
f49e7000-f49e8000 rwxs 00000000 00:05 118467 /drm mm object (deleted)
f49e8000-f49e9000 rwxs 00000000 00:05 118466 /drm mm object (deleted)
f49e9000-f49ea000 rwxs 00000000 00:05 118465 /drm mm object (deleted)
f49ea000-f49eb000 rwxs 00000000 00:05 118464 /drm mm object (deleted)
f49eb000-f49ec000 rwxs 00000000 00:05 118463 /drm mm object (deleted)
f49ec000-f49ed000 rwxs 00000000 00:05 118462 /drm mm object (deleted)
f49ed000-f49ee000 rwxs 00000000 00:05 118461 /drm mm object (deleted)
f49ee000-f49ef000 rwxs 00000000 00:05 118460 /drm mm object (deleted)
f49ef000-f49f0000 rwxs 00000000 00:05 118459 /drm mm object (deleted)
f49f0000-f49f1000 rwxs 00000000 00:05 118458 /drm mm object (deleted)
f49f1000-f49f2000 rwxs 00000000 00:05 118457 /drm mm object (deleted)
f49f2000-f49f3000 rwxs 00000000 00:05 118456 /drm mm object (deleted)
f49f3000-f49f4000 rwxs 00000000 00:05 118455 /drm mm object (deleted)
f49f4000-f49f5000 rwxs 00000000 00:05 118454 /drm mm object (deleted)
f49f5000-f49f6000 rwxs 00000000 00:05 118453 /drm mm object (deleted)
f49f6000-f49f7000 rwxs 00000000 00:05 118452 /drm mm object (deleted)
f49f7000-f49f8000 rwxs 00000000 00:05 118451 /drm mm object (deleted)
f49f8000-f49f9000 rwxs 00000000 00:05 118450 /drm mm object (deleted)
f49f9000-f49fa000 rwxs 00000000 00:05 118449 /drm mm object (deleted)
f49fa000-f49fb000 rwxs 00000000 00:05 118448 /drm mm object (deleted)
f49fb000-f49fc000 rwxs 00000000 00:05 118447 /drm mm object (deleted)
f49fc000-f49fd000 rwxs 00000000 00:05 118446 /drm mm object (deleted)
f49fd000-f49fe000 rwxs 00000000 00:05 118445 /drm mm object (deleted)
f49fe000-f49ff000 rwxs 00000000 00:05 118444 /drm mm object (deleted)
f49ff000-f4a00000 rwxs 00000000 00:05 118443 /drm mm object (deleted)
f4a00000-f4a01000 rwxs 00000000 00:05 118442 /drm mm object (deleted)
f4a01000-f4a02000 rwxs 00000000 00:05 118441 /drm mm object (deleted)
f4a02000-f4a03000 rwxs 00000000 00:05 118440 /drm mm object (deleted)
f4a03000-f4a04000 rwxs 00000000 00:05 118439 /drm mm object (deleted)
f4a04000-f4a05000 rwxs 00000000 00:05 118438 /drm mm object (deleted)
f4a05000-f4a06000 rwxs 00000000 00:05 118437 /drm mm object (deleted)
f4a06000-f4a07000 rwxs 00000000 00:05 118436 /drm mm object (deleted)
f4a07000-f4a08000 rwxs 00000000 00:05 118435 /drm mm object (deleted)
f4a08000-f4a09000 rwxs 00000000 00:05 118434 /drm mm object (deleted)
f4a09000-f4a0a000 rwxs 00000000 00:05 118433 /drm mm object (deleted)
f4a0a000-f4a0b000 rwxs 00000000 00:05 118432 /drm mm object (deleted)
f4a0b000-f4a0c000 rwxs 00000000 00:05 118431 /drm mm object (deleted)
f4a0c000-f4a0d000 rwxs 00000000 00:05 118430 /drm mm object (deleted)
f4a0d000-f4aad000 rwxs 101094000 00:06 35 /dev/dri/card0
f4aad000-f4ae5000 rwxs 101d74000 00:06 35 /dev/dri/card0
f4ae5000-f4c0e000 rwxp 00000000 00:00 0
f4c0e000-f4c8e000 rwxs 101c84000 00:06 35 /dev/dri/card0
f4c8e000-f4c8f000 rwxs 00000000 00:05 118429 /drm mm object (deleted)
f4c8f000-f4c90000 rwxs 00000000 00:05 118428 /drm mm object (deleted)
f4c90000-f4c91000 rwxs 00000000 00:05 118427 /drm mm object (deleted)
f4c91000-f4c92000 rwxs 00000000 00:05 118426 /drm mm object (deleted)
f4c92000-f4c93000 rwxs 00000000 00:05 118425 /drm mm object (deleted)
f4c93000-f4c94000 rwxs 00000000 00:05 118424 /drm mm object (deleted)
f4c94000-f4c95000 rwxs 00000000 00:05 118423 /drm mm object (deleted)
f4c95000-f4c96000 rwxs 00000000 00:05 118422 /drm mm object (deleted)
f4c96000-f4c97000 rwxs 00000000 00:05 118421 /drm mm object (deleted)
f4c97000-f4c98000 rwxs 00000000 00:05 118420 /drm mm object (deleted)
f4c98000-f4c99000 rwxs 00000000 00:05 118419 /drm mm object (deleted)
f4c99000-f4c9a000 rwxs 00000000 00:05 118418 /drm mm object (deleted)
f4c9a000-f4c9b000 rwxs 00000000 00:05 118417 /drm mm object (deleted)
f4c9b000-f4c9c000 rwxs 00000000 00:05 118416 /drm mm object (deleted)
f4c9c000-f4c9d000 rwxs 00000000 00:05 118414 /drm mm object (deleted)
f4c9d000-f4c9e000 rwxs 00000000 00:05 118413 /drm mm object (deleted)
f4c9e000-f4c9f000 rwxs 00000000 00:05 118412 /drm mm object (deleted)
f4c9f000-f4ca0000 rwxs 00000000 00:05 118411 /drm mm object (deleted)
f4ca0000-f4ca1000 rwxs 00000000 00:05 118409 /drm mm object (deleted)
f4ca1000-f4ca2000 rwxs 00000000 00:05 118408 /drm mm object (deleted)
f4ca2000-f4ca3000 rwxs 00000000 00:05 117310 /drm mm object (deleted)
f4ca3000-f4ca4000 rwxs 00000000 00:05 117309 /drm mm object (deleted)
f4ca4000-f4ca5000 rwxs 00000000 00:05 117308 /drm mm object (deleted)
f4ca5000-f4ca6000 rwxs 00000000 00:05 117307 /drm mm object (deleted)
f4ca6000-f4ca7000 rwxs 00000000 00:05 117306 /drm mm object (deleted)
f4ca7000-f4ca8000 rwxs 00000000 00:05 117305 /drm mm object (deleted)
f4ca8000-f4ca9000 rwxs 00000000 00:05 117274 /drm mm object (deleted)
f4ca9000-f4caa000 rwxs 00000000 00:05 117273 /drm mm object (deleted)
f4caa000-f4cab000 rwxs 00000000 00:05 117272 /drm mm object (deleted)
f4cab000-f4cac000 rwxs 00000000 00:05 117271 /drm mm object (deleted)
f4cac000-f4cad000 rwxs 00000000 00:05 117270 /drm mm object (deleted)
f4cad000-f4cae000 rwxs 00000000 00:05 117269 /drm mm object (deleted)
f4cae000-f4caf000 rwxs 00000000 00:05 117268 /drm mm object (deleted)
f4caf000-f4cb0000 rwxs 00000000 00:05 117267 /drm mm object (deleted)
f4cb0000-f4cb1000 rwxs 00000000 00:05 117266 /drm mm object (deleted)
f4cb1000-f4cb2000 rwxs 00000000 00:05 117265 /drm mm object (deleted)
f4cb2000-f4cb3000 rwxs 00000000 00:05 117264 /drm mm object (deleted)
f4cb3000-f4cb5000 rwxs 1007f1000 00:06 35 /dev/dri/card0
f4cb5000-f4cb6000 rwxs 1007f0000 00:06 35 /dev/dri/card0
f4cb6000-f4cb7000 rwxs 1007ef000 00:06 35 /dev/dri/card0
f4cb7000-f4cb8000 rwxs 1007ee000 00:06 35 /dev/dri/card0
f4cb8000-f4cb9000 rwxs 1007ed000 00:06 35 /dev/dri/card0
f4cb9000-f4cba000 rwxs 1007ec000 00:06 35 /dev/dri/card0
f4cba000-f4cbb000 rwxs 1007eb000 00:06 35 /dev/dri/card0
f4cbb000-f4cbc000 rwxs 1007ea000 00:06 35 /dev/dri/card0
f4cbc000-f4cbd000 rwxs 1007e9000 00:06 35 /dev/dri/card0
f4cbd000-f4cbe000 rwxs 1007e8000 00:06 35 /dev/dri/card0
f4cbe000-f4cbf000 rwxs 1007e7000 00:06 35 /dev/dri/card0
f4cbf000-f4cc0000 rwxs 1007e6000 00:06 35 /dev/dri/card0
f4cc0000-f4cc1000 rwxs 1007e5000 00:06 35 /dev/dri/card0
f4cc1000-f4cc2000 rwxs 1007e4000 00:06 35 /dev/dri/card0
f4cc2000-f4cc3000 rwxs 00000000 00:05 117249 /drm mm object (deleted)
f4cc3000-f4cc4000 rwxs 00000000 00:05 117248 /drm mm object (deleted)
f4cc4000-f4cc5000 rwxs 00000000 00:05 117247 /drm mm object (deleted)
f4cc5000-f4cc6000 rwxs 1007e3000 00:06 35 /dev/dri/card0
f4cc6000-f4cc7000 rwxs 1007e2000 00:06 35 /dev/dri/card0
f4cc7000-f4cc8000 rwxs 1007e1000 00:06 35 /dev/dri/card0
f4cc8000-f4cc9000 rwxs 1007e0000 00:06 35 /dev/dri/card0
f4cc9000-f4cca000 rwxs 1007df000 00:06 35 /dev/dri/card0
f4cca000-f4ccb000 rwxs 1007de000 00:06 35 /dev/dri/card0
f4ccb000-f4ccc000 rwxs 1007dd000 00:06 35 /dev/dri/card0
f4ccc000-f4ccd000 rwxs 1007dc000 00:06 35 /dev/dri/card0
f4ccd000-f4cce000 rwxs 1007db000 00:06 35 /dev/dri/card0
f4cce000-f4ccf000 rwxs 1007da000 00:06 35 /dev/dri/card0
f4ccf000-f4cd0000 rwxs 1007d9000 00:06 35 /dev/dri/card0
f4cd0000-f4cd1000 rwxs 1007d8000 00:06 35 /dev/dri/card0
f4cd1000-f4cd2000 rwxs 1007d7000 00:06 35 /dev/dri/card0
f4cd2000-f4cd3000 rwxs 1007d6000 00:06 35 /dev/dri/card0
f4cd3000-f4cd4000 rwxs 1007d5000 00:06 35 /dev/dri/card0
f4cd4000-f4cd5000 rwxs 1007d4000 00:06 35 /dev/dri/card0
f4cd5000-f4cd6000 rwxs 1007d3000 00:06 35 /dev/dri/card0
f4cd6000-f4cd7000 rwxs 1007d2000 00:06 35 /dev/dri/card0
f4cd7000-f4cd8000 rwxs 1007d1000 00:06 35 /dev/dri/card0
f4cd8000-f4cd9000 rwxs 1007d0000 00:06 35 /dev/dri/card0
f4cd9000-f4cda000 rwxs 1007cf000 00:06 35 /dev/dri/card0
f4cda000-f4cdb000 rwxs 1007ce000 00:06 35 /dev/dri/card0
f4cdb000-f4cdc000 rwxs 1007cd000 00:06 35 /dev/dri/card0
f4cdc000-f4cdd000 rwxs 1007cc000 00:06 35 /dev/dri/card0
f4cdd000-f4cde000 rwxs 1007cb000 00:06 35 /dev/dri/card0
f4cde000-f4cdf000 rwxs 1007ca000 00:06 35 /dev/dri/card0
f4cdf000-f4ce0000 rwxs 1007c9000 00:06 35 /dev/dri/card0
f4ce0000-f4ce1000 rwxs 1007c8000 00:06 35 /dev/dri/card0
f4ce1000-f4ce2000 rwxs 1007c7000 00:06 35 /dev/dri/card0
f4ce2000-f4ce3000 rwxs 1007c6000 00:06 35 /dev/dri/card0
f4ce3000-f4ce4000 rwxs 00000000 00:05 117214 /drm mm object (deleted)
f4ce4000-f4ce5000 rwxs 00000000 00:05 117213 /drm mm object (deleted)
f4ce5000-f4ce6000 rwxs 1007c5000 00:06 35 /dev/dri/card0
f4ce6000-f4ce7000 rwxs 1007c4000 00:06 35 /dev/dri/card0
f4ce7000-f4ce8000 rwxs 1007c3000 00:06 35 /dev/dri/card0
f4ce8000-f4ce9000 rwxs 1007c2000 00:06 35 /dev/dri/card0
f4ce9000-f4cea000 rwxs 00000000 00:05 117207 /drm mm object (deleted)
f4cea000-f4ceb000 rwxs 00000000 00:05 117206 /drm mm object (deleted)
f4ceb000-f4cec000 rwxs 00000000 00:05 117205 /drm mm object (deleted)
f4cec000-f4ced000 rwxs 00000000 00:05 117204 /drm mm object (deleted)
f4ced000-f4cee000 rwxs 00000000 00:05 117203 /drm mm object (deleted)
f4cee000-f4cef000 rwxs 00000000 00:05 117202 /drm mm object (deleted)
f4cef000-f4cf0000 rwxs 00000000 00:05 117201 /drm mm object (deleted)
f4cf0000-f4cf1000 rwxs 00000000 00:05 117200 /drm mm object (deleted)
f4cf1000-f4d01000 rwxs 100651000 00:06 35 /dev/dri/card0
f4d01000-f4d02000 rwxs 00000000 00:05 117197 /drm mm object (deleted)
f4d02000-f4d03000 rwxs 00000000 00:05 117196 /drm mm object (deleted)
f4d03000-f4d04000 rwxs 00000000 00:05 117195 /drm mm object (deleted)
f4d04000-f4d05000 rwxs 00000000 00:05 117194 /drm mm object (deleted)
f4d05000-f4d06000 rwxs 00000000 00:05 117193 /drm mm object (deleted)
f4d06000-f4d07000 rwxs 00000000 00:05 117192 /drm mm object (deleted)
f4d07000-f4d08000 rwxs 00000000 00:05 117191 /drm mm object (deleted)
f4d08000-f4d09000 rwxs 00000000 00:05 117190 /drm mm object (deleted)
f4d09000-f4d0a000 rwxs 00000000 00:05 117189 /drm mm object (deleted)
f4d0a000-f4d0b000 rwxs 00000000 00:05 117188 /drm mm object (deleted)
f4d0b000-f4d0c000 rwxs 00000000 00:05 117187 /drm mm object (deleted)
f4d0c000-f4d0d000 rwxs 00000000 00:05 117186 /drm mm object (deleted)
f4d0d000-f4d0e000 rwxs 00000000 00:05 117185 /drm mm object (deleted)
f4d0e000-f4d0f000 rwxs 00000000 00:05 117184 /drm mm object (deleted)
f4d0f000-f4d10000 rwxs 00000000 00:05 117183 /drm mm object (deleted)
f4d10000-f4d11000 rwxs 00000000 00:05 117182 /drm mm object (deleted)
f4d11000-f4d12000 rwxs 00000000 00:05 117181 /drm mm object (deleted)
f4d12000-f4d82000 rwxs 101d04000 00:06 35 /dev/dri/card0
f4d82000-f4d92000 rwxs 101c74000 00:06 35 /dev/dri/card0
f4d92000-f605f000 rwxp 00000000 00:00 0
f605f000-f6063000 r-xp 00000000 08:03 2511605 /usr/lib32/libtxc_dxtn.so
f6063000-f6064000 r-xp 00003000 08:03 2511605 /usr/lib32/libtxc_dxtn.so
f6064000-f6065000 rwxp 00004000 08:03 2511605 /usr/lib32/libtxc_dxtn.so
f6065000-f606f000 r-xp 00000000 08:03 2511429 /usr/lib32/libpciaccess.so.0.11.1
f606f000-f6071000 r-xp 00009000 08:03 2511429 /usr/lib32/libpciaccess.so.0.11.1
f6071000-f6072000 rwxp 0000b000 08:03 2511429 /usr/lib32/libpciaccess.so.0.11.1
f6072000-f6086000 r-xp 00000000 08:03 2511459 /usr/lib32/libgpg-error.so.0.19.1
f6086000-f6087000 r-xp 00013000 08:03 2511459 /usr/lib32/libgpg-error.so.0.19.1
f6087000-f6088000 rwxp 00014000 08:03 2511459 /usr/lib32/libgpg-error.so.0.19.1
f6088000-f6094000 r-xp 00000000 08:03 2509781 /usr/lib32/libdrm_radeon.so.1.0.1
f6094000-f6095000 r-xp 0000b000 08:03 2509781 /usr/lib32/libdrm_radeon.so.1.0.1
f6095000-f6096000 rwxp 0000c000 08:03 2509781 /usr/lib32/libdrm_radeon.so.1.0.1
f6096000-f609e000 r-xp 00000000 08:03 2509780 /usr/lib32/libdrm_nouveau.so.2.0.0
f609e000-f609f000 r-xp 00007000 08:03 2509780 /usr/lib32/libdrm_nouveau.so.2.0.0
f609f000-f60a0000 rwxp 00008000 08:03 2509780 /usr/lib32/libdrm_nouveau.so.2.0.0
f60a0000-f60c3000 r-xp 00000000 08:03 2509779 /usr/lib32/libdrm_intel.so.1.0.0
f60c3000-f60c4000 r-xp 00022000 08:03 2509779 /usr/lib32/libdrm_intel.so.1.0.0
f60c4000-f60c5000 rwxp 00023000 08:03 2509779 /usr/lib32/libdrm_intel.so.1.0.0
f60c5000-f618f000 r-xp 00000000 08:03 2511462 /usr/lib32/libgcrypt.so.20.1.3
f618f000-f6190000 r-xp 000c9000 08:03 2511462 /usr/lib32/libgcrypt.so.20.1.3
f6190000-f6193000 rwxp 000ca000 08:03 2511462 /usr/lib32/libgcrypt.so.20.1.3
f6193000-f68af000 r-xp 00000000 08:03 394921 /usr/lib32/xorg/modules/dri/i965_dri.so
f68af000-f68b0000 ---p 0071c000 08:03 394921 /usr/lib32/xorg/modules/dri/i965_dri.so
f68b0000-f68d9000 r-xp 0071c000 08:03 394921 /usr/lib32/xorg/modules/dri/i965_dri.so
f68d9000-f68df000 rwxp 00745000 08:03 394921 /usr/lib32/xorg/modules/dri/i965_dri.so
f68df000-f68e5000 rwxp 00000000 00:00 0
f68e5000-f68e9000 r-xp 00000000 08:03 2511556 /usr/lib32/libcap.so.2.25
f68e9000-f68ea000 rwxp 00003000 08:03 2511556 /usr/lib32/libcap.so.2.25
f68ea000-f68eb000 rwxs 00000000 00:05 117180 /drm mm object (deleted)/usr/bin/textmaker16: line 4: 6154 Abortado (imagem do núcleo gravada)/opt/smoffice2016/textmaker "$SMOFFICE_GUI" "$@"
Michael Uplawski
Post by Michael Uplawski » Sat Oct 08, 2016 7:01 am
Hi vitor.
I am a little embarrassed, because after experiencing so many GTK/Gnome induced problems myself, I should now know something about it. But alas! Neither digging into the GTK-code nor scrutinizing the diverse discussion-platforms for information could become any of my favorite occupations. In fact, things like “failed to retrieve property `gtk-primary-button-warps-slider' of type `gboolean' from rc file value "((GString*) 0x15068a0)" of type `gboolean'” are never apt to arouse my curiosity enough.
In summary: This is not a problem of SoftMaker Office. It may though indicate a nasty incompatibility between SoftMaker Office and your current desktop-environment. This happened in the past, happens, must happen and will.
Can you name your current desktop-environment and its version, please?
And try this please: In the TextMaker menu enter Tools|Options. On the tab “AppearancedeactivateWindow Manager dialogs”. Report, if it does something. I am just guessing and the attempt may fail, anyway... miserably.
In the most beautiful language in the world (sound-wise) it is: Ferramentas|Opções|Apparência and the option Diálogos do Window Manager
vitor895
Post by vitor895 » Sat Oct 08, 2016 3:09 pm
Hi Michael Uplawski
I'm using KDE Plasma 5.8 and disabled “Window Manager dialogs”, but unfortunately yet segmentation fault. Sometimes updates in Arch's software cause weird problems. I'll wait some months and see what happens.
Thank you very much for answers
Attachments: installed software and hardware info
attachments.tar.gz
(28.83 KiB) Downloaded 77 times
Return to “TextMaker 2016 for Linux”
