Loss of icons
Post your questions, bug reports and suggestions here for TextMaker 2016 for Linux.
dre
Loss of icons
Post by dre » Fri Aug 12, 2016 5:27 am
In TextMaker for linux (deb version), if I change the UI appearance, eventually I'll lose the menu-bar icons (see attached pic).
In this case I changed the UI to dark and the font smoothing to greyscale and lost all the icons. The only way to fix this is to delete tm16config.ini in ~/.softmaker.
OS is Linux Mint 18.3.
Re: Loss of icons
Post by sven-l » Fri Aug 12, 2016 11:43 am
Could you please attach your pic again? Thank you!
Return to “TextMaker 2016 for Linux”
