Very small font in UI and menus in Linux (solved)
Post your questions, bug reports and suggestions here for TextMaker 2016 for Linux.
phaidros52
Post by phaidros52 » Fri Dec 18, 2015 10:53 am
Hi,
I have the new Linux version with Duden (not the beta anymore) and only in Textmaker the font for the UI and in menus is very small. Actually so small that I cant see the figures for the word count for example. How can I change the size of the font for the UI?
Ph.
Michael Uplawski
Re: Very small font in UI and menues
Post by Michael Uplawski » Sat Dec 19, 2015 8:09 am
There is a nifty little feature in SoftMaker Office that allows modifications
to the size of UI-controls and fonts.
You find it under Tools | Options. Choose the tab “Appearance”. I must change
the control-size to get control over the slider that adjusts the font. In
setting “Normal” I am unable to change the font-size. But in “Large”, this
works just fine.
Report back, if this does what you want.
Screen shot.
Michael
The configuration dialog
People should go where they are not supposed to go, say what they are not supposed to say and stay, when they are told to leave.” (Howard Zinn)
phaidros52
Post by phaidros52 » Sun Dec 20, 2015 9:27 am
Hi Michael,
thank you for the hint. It works even though there is still a
little glitch in the selecting method and the offered sizes. But OK.
Should mention that this solution is only for Linux.
Ph.
Re: Very small font in UI and menus in Linux (solved)
Post by martin-k » Sun Dec 20, 2015 11:08 am
Change the dialog style from "Linux (gray)" to "Linux (system)", and it will use the UI font used by Gnome, KDE or Unity (whatever is active).
Return to “TextMaker 2016 for Linux”
