UI | Page alignment problem
Post your questions, bug reports and suggestions here for TextMaker 2016 for Linux.
attilas
Post by attilas » Thu Dec 10, 2015 2:16 pm
If I maximize the TextMaker's window, and I hide the sidebar, then the page become aligned to left. But if I enable the sidebar again, it become aligned to center. If I un-maximize it's window then it become aligned to center, even if sidebar hidden.
I attached screenshots.
(Sorry for my basic English)
Robin Holt
Re: UI | Page alignment problem
Post by Robin Holt » Thu Dec 10, 2015 3:04 pm
I'm not sure about the Linux version, but the Windows product has a simple solution. Go to Tools>Options and look at the View tab. Toward the bottom there are a couple of boxes under "View Options" One of these boxes is "Show multiple pages side by side". If that option is checked, then uncheck it. That should fix the problem.
attilas
Post by attilas » Thu Dec 10, 2015 4:43 pm
Thank you Robbin, your suggestion works. 8-)
Michael Uplawski
Post by Michael Uplawski » Sun Dec 13, 2015 10:35 am
attilas wrote:Thank you Robbin, your suggestion works. 8-)
I am undecided but might call it a bug anyway. Else each software that allows you to disable malfunctions could add 1 named feature to its account of adulation.
People should go where they are not supposed to go, say what they are not supposed to say and stay, when they are told to leave.” (Howard Zinn)
attilas
Post by attilas » Sun Dec 13, 2015 9:48 pm
That's right, it is a bug.
But what can I do?
Should I hire a programmer and send to SoftMaker to fix my issues?
:roll:
Post by martin-k » Thu Dec 17, 2015 11:43 am
It's not a bug. When there is enough space on the screen (sidebar hidden), TextMaker by default tries to show two pages side by side. When you activate the sidebar, the usable area gets smaller and there is not enough room for two pages. TextMaker then displays one page, centered.
You can check this by adding a second page to the document, activating the sidebar and reducing the zoom level. Below some point, two pages will be shown side by side.
attilas
Post by attilas » Thu Dec 17, 2015 2:22 pm
Martin, thank you for the explanation.
Return to “TextMaker 2016 for Linux”
