Oops! I made the Appearance twice to big
Post here those questions, bug reports and suggestions for SoftMaker Office 2016 for Linux that do not fit in any of the application-specific subforums.
AZgl1800
Post by AZgl1800 » Sun Jan 14, 2018 6:48 am
and now, half of the Options menu is below the bottom of the screen.
I can't access the "Reset to Defaults" to get things back to normal.
I know there is a Template for booting it up, just like in MS Word, and if I can edit that template, I could fix my problem.
Tnx in advance for your help
John
in OkieLand
Re: Oops! I made the Appearance twice to big
Post by sven-l » Fri Jan 19, 2018 2:54 pm
You could try to delete the config file (e.g. tml18config.ini for TextMaker) in /home/.softmaker. This will reset all changes you made to the program window.
Return to “SoftMaker Office 2016 for Linux (General)”
