Won't take the product key
Post here those questions, bug reports and suggestions for SoftMaker Office 2016 for Linux that do not fit in any of the application-specific subforums.
PaulCoy
Post by PaulCoy » Sun Apr 30, 2017 7:49 am
Wont take the product key.
Error 107
Linux Mint 18 I just reinstalled today. re-adding SoftMaker.
Much better that LibreOffice IMHO.
Re: Won't take the product key
Post by martin-k » Sun Apr 30, 2017 12:51 pm
Delete the license file (ofres16.lic or of2016.lic) and start TextMaker again, then enter the key once more.
PaulCoy
Post by PaulCoy » Mon May 01, 2017 5:39 am
So, where would find this magic file at? I looked in /usr/share/freeoffice2016/ and found something similar but not with a ".lic" extension. I think it had a ".dat" extension.
PaulCoy
Post by PaulCoy » Mon May 01, 2017 5:49 am
Update: Some how my /home.softmaker is now owned by root. I will fix that and get back to you. (I also found the ".lic" file in there.)
Post by martin-k » Mon May 01, 2017 8:58 am
PaulCoy wrote:Update: Some how my /home.softmaker is now owned by root. I will fix that and get back to you. (I also found the ".lic" file in there.)
That would explain the issue, because SoftMaker Office can't access the file with these rights.
PaulCoy
Post by PaulCoy » Tue May 02, 2017 4:16 am
I changed the rights to .softmaker and about 8 other .* directories. Removed the ".lic" file. Actually reloaded from the .deb. Re ran TextMaker. Put in the key and now the computer and I are happy campers.
I do need to review my backup/restore procedures for "next time".
Thanks for your help. =D>
mychance
Post by mychance » Tue Jun 06, 2017 1:27 am
I just had a similar problem when upgrading from standard to professionnal version of Softmaker Office. After the installation I was still under the standard version and was not asked for a product key. I just deleted the home/.softmaker folder, was then asked for the product key and finally got the professionnal version. I am using Linux Mint 17.1.
Return to “SoftMaker Office 2016 for Linux (General)”
