Segmentation Fault
Post here those questions, bug reports and suggestions for SoftMaker Office 2016 for Linux that do not fit in any of the application-specific subforums.
weemax
Segmentation Fault
Post by weemax » Sun Apr 30, 2017 12:45 am
Distro: Fedora 25
NVidia Driver: 375.39 64-bit
Code: Select all
$ textmaker16
usr/bin/textmaker16: line 3: 3331 Segmentation fault	(core dumped) LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/share/office2016/dpf /usr/share/office2016/textmaker "$@"
Code: Select all
$ strace -f textmaker16 2>output.txt
Please follow https://pastebin.com/XF54fQAW for output.txt
Re: Segmentation Fault
Post by sven-l » Thu May 04, 2017 11:05 am
Thank you for the crash report. Could you please send us the tmlog.txt?
Please run TextMaker with the -debug parameter (Start the terminal and enter ‘textmaker16 -debug’ without the ‘).
Return to “SoftMaker Office 2016 for Linux (General)”
