Internet connection needed for every start up
Post here those questions, bug reports and suggestions for SoftMaker Office 2016 for Linux that do not fit in any of the application-specific subforums.
LanceGary
Post by LanceGary » Sat Dec 12, 2015 1:27 pm
It seems that the copy of Softmaker 2016 for Linux that I have requires an internet connection every time the software starts (not just once). Please tell me that this can be fixed?
Lance
attilas
Re: Internet connection needed for every start up
Post by attilas » Sat Dec 12, 2015 6:05 pm
I checked it, and you are right! Mr Spock would say: Fascinating :!:
Post by sven-l » Mon Dec 14, 2015 8:25 am
I installed the Office in an Ubuntu 14.04.2 64bit, activated it and disabled the network card (no internet connection anymore). Afterwards I could start every program, even after a new boot of the system. Could you please tell us which server SoftMaker Office wants to connect? Thank you!
LanceGary
Post by LanceGary » Mon Dec 14, 2015 1:55 pm
I am not terribly sure what you are asking.
I am using Linux Mint 17.3 on an ordinary PC (Intel NUC).
If I am not connected to the web Softmaker 2016 just states that I do not have enough permissions to run the software and stops.
If I am connected to the web Softmaker Office 2016 runs. This happens with each of the components.
I am using the licence key you sent me when I pre-paid for Softmaker Offuce 2016.
Thanks for any help,
Lance
attilas
Post by attilas » Mon Dec 14, 2015 2:42 pm
I attached the error message I get.
I wrote about this issue to the support, and they asked for details, and I provided it to them, which is:
1) I enter this product key: [my key] to successfully unlock the office suite.
2) Close the office.
3) Completely disconnect the computer from the internet. (Make sure you are not connected via wifi, lan, 3g, or any other way.)
4) Start the office, I started TextMaker.
5) And after that I get the mentioned error: “The application cannot create a unique identifier. Please make sure the application has sufficient permissions. Retry / Cancel”
My current Linux is OpenSUSE Tumbleweed x86-64 20151209
I used this Installer: softmaker-office-2016-749.x86_64.rpm
Beforehand the beta (softmaker-office-2016-748.x86_64.rpm) was installed on my system, but before installing the 749 version I removed it, even the config directory in the home (.softmaker)
jeroen
Post by jeroen » Mon Dec 14, 2015 3:01 pm
Exactly the same message appears when I disconnect my computer.
Jim-J
Post by Jim-J » Mon Dec 14, 2015 4:11 pm
To all that have this problem:
Can you please send us your sminfo.txt (Help->About->Write System information) to forum(at)softmaker.de
Please don't forget to write your forum alias and the link of your post.
Thank you.
Jim J.
Jim-J
Post by Jim-J » Fri Dec 18, 2015 2:04 pm
This issue should be fixed with the next service pack. Please try out when it's released and report if it occurs again.
Jim J.
attilas
Post by attilas » Fri Dec 18, 2015 4:00 pm
Jim-J wrote:This issue should be fixed with the next service pack. Please try out when it's released and report if it occurs again.
Approximately, when will be released this service pack?
Post by sven-l » Mon Dec 21, 2015 11:06 am
There is no release date yet. We will inform you as soon it has been finished.
Post by sven-l » Tue Dec 22, 2015 1:14 pm
I sent you a Hotfix.
attilas
Post by attilas » Tue Dec 22, 2015 2:27 pm
Thank you, but the problem still there.
Are there any special instructions to install?
Post by martin-k » Tue Dec 22, 2015 2:31 pm
You need to replace the files in the SoftMaker Office program folder with the files in the .tgz file.
attilas
Post by attilas » Tue Dec 22, 2015 3:43 pm
martin-k wrote:You need to replace the files in the SoftMaker Office program folder with the files in the .tgz file.
OK. The hotfix (ofl16_hotfix_7077.tgz) does not fix this issue.
Post by sven-l » Tue Jan 05, 2016 11:27 am
Thank you.
Return to “SoftMaker Office 2016 for Linux (General)”
