[SOLVED] Missing libpcre.so.3 library
Post bug reports and suggestions for PlanMaker 2016 Beta for Linux.
darzki
Postby darzki » Thu Oct 08, 2015 5:05 pm
After fresh installation using shell installation script (works great for single user!) PlanMaker does not start.
It seems like arch version of lib32-pcre package does not provide libpcre.so.3 library, so I had to create symlink for it to start:
Code: Select all
ln -s /usr/lib32/libpcre.so /usr/lib32/libpcre.so.3
After that PlanMaker starts and works just fine (for now).
System info:
Arch Linux 4.2.2 x86_64; KDE 5.4
mcolligan
Re: Missing libpcre.so.3 library
Postby mcolligan » Thu Oct 08, 2015 5:13 pm
I noticed this when uninstalling SoftMaker 2016. Removing via dnf erase (rpm):
Removing icons from the desktop...
Erasing : softmaker-office-2016-745.i386 1/7
warning: file /usr/share/office2016/dpf/libpcre.so.3.12.1: remove failed: No such file or directory
FYI...
Michael
mura
Postby mura » Thu Oct 08, 2015 10:25 pm
Slackware64 13.1
TextMaker starts without problems, but:
bash-4.2$ /home/mura/planmaker16 %F
/home/mura/office2016/planmaker: error while loading shared libraries: libpcre.so.3: cannot open shared object file: No such file or directory
bash-4.2$ /home/mura/presentations16 %F
/home/mura/office2016/presentations: error while loading shared libraries: libpcre.so.3: cannot open shared object file: No such file or directory
LarryDC
Postby LarryDC » Fri Oct 09, 2015 12:15 am
I'm running this in a daily updated Arch Linux variant "BlueStar Linux."
When installing via the shell (.tgz) installation as root into /opt/office2016, I received:
However the solution is differnt since the correct softlink is ALREADY installed.
The problem is that "ldconfig" must be run as root.
So you need to add it to the installation script after creating the softlinks.
Otherwise running fine except all these errors (I'm running it out of a konsole window to see them.) when running the Open file dialog:
C_hdinfo::C_hdinfo: mz_mnt_fsname = LABEL=Swap16G: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = LABEL=Bluestar: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = LABEL=home_1T: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = LABEL=storage: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = LABEL=Video: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = LABEL=Large: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = LABEL=XP_Data: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = proc: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = sys: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = dev: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = run: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = securityfs: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = tmpfs: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = devpts: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = cgroup: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = pstore: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = systemd-1: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = hugetlbfs: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = mqueue: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = debugfs: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = binfmt_misc: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = configfs: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = fusectl: No such file or directory
C_hdinfo::C_hdinfo: mz_mnt_fsname = gvfsd-fuse: No such file or directory
Bradenton Florida 34210-4228
Registered Linux User #305687 (BlueStar, Calculate, MX-14, PicarOS, & Mageia 5)
Jim-J
Postby Jim-J » Mon Oct 12, 2015 1:44 pm
Hello,
We know about this issue. Our developers are working on it.
Thank you.
Jim J.
Return to “Beta: PlanMaker 2016 for Linux”
Who is online
