Jumping Search and Replace dialogue box
Post bug reports and suggestions for TextMaker 2016 Beta for Linux.
Alexander
Post by Alexander » Sat Nov 21, 2015 1:37 pm
The Search and Replace dialogue box changes size when switching between the Search and Replace tabs. In itself this is somewhat unconventional, but probably intended. However, when the box is moved after invocation (e.g. via Ctrl+F) to render an obscured part of the screen visible, and tabs are switched after moving the box, the box immediately jumps back to a position at the bottom of the screen, forcing me to move the box again. This resembles a bug : ) Note that user-indicated box positions are also not remembered.
Suggested solution: single-size Search and Replace dialogue box, with a user-definable and persistent position on the screen, or simply a panel in the margin to ensure it never obscures the text.
Re: Jumping Search and Replace dialogue box
Post by sven-l » Mon Nov 30, 2015 5:14 pm
Which Linux distribution are you using?
Alexander
Post by Alexander » Mon Nov 30, 2015 8:37 pm
I'm running Ubuntu 14.04 LTS.
Post by sven-l » Mon Dec 07, 2015 9:51 am
I can reproduce that issue and will inform the developers. Thank you!
Return to “Beta: TextMaker 2016 for Linux”
