[SOLVED] run textmaker on archlinux
Post bug reports and suggestions for TextMaker 2016 Beta for Linux.
makan
Post by makan » Fri Oct 30, 2015 7:46 am
hi all,
i have install softmaker-office-pro-2016-747 tgz version on archlinux.
presentations16 and planmaker16 running smoothly, however textmaker16 is failed to run
$ textmaker16
/usr/share/office2016/textmaker: error while loading shared libraries: libdle.so.1: cannot open shared object file: No such file or directory
what is package name for libdle.so.1 ?
thank you
makan
Re: run textmaker on archlinux
Post by makan » Fri Oct 30, 2015 8:00 am
ok it seems i need to run
Code: Select all
ldconfig
before i can start textmaker16
case solved... :D
Return to “Beta: TextMaker 2016 for Linux”
