Search and Replace
Post bug reports and suggestions for TextMaker 2016 Beta for Linux.
Phyzzy2013
Search and Replace
Post by Phyzzy2013 » Thu Oct 08, 2015 11:03 pm
Search and Replace works textwise but does not change character formatting.
Ubuntu Linux 14.04LTS
Re: Search and Replace
Post by sven-l » Wed Oct 14, 2015 11:43 am
Have you enabled "Search from Top" in the replace dialog window? I cheked it and it was possible to replace text and simultaneously change the text formatting.
Phyzzy2013
Post by Phyzzy2013 » Wed Nov 18, 2015 11:59 am
Yes, I checked "replace from the top".
It work character, paragraph and paragraph style but not character style. It reports the correct number of replacements but the formatting is not changed.
Scipios Traum.tmd
(49.39 KiB) Downloaded 72 times
Post by sven-l » Mon Nov 23, 2015 4:41 pm
Ok, thank you! So far I could search for character styles (after I assigned one of them to some of the text in you sample file) and replace it with another style. Could you please describe step by step how you did it when replacing did not work? Thank you!
Return to “Beta: TextMaker 2016 for Linux”
