Cannot install beta on CentOS 6 due to libudev version issue
Post bug reports and suggestions here for SoftMaker Office 2016 for Linux Beta that do not fit in any of the application-specific subforums.
wvh
Post by wvh » Sat Nov 21, 2015 3:35 am
The last closed beta and the new open beta of SoftMaker office require libudev.so.1, while CentOS 6 (and thus, presumably, RedHat 6) only provide libudev.so.0. This makes it impossible for me to install these betas from the RPM. I can, of course, still successfully install from the tarball, but I'd think that you'd want to encourage the use of RPMs for enterprise or multi-user scenarios. Do you really need libudev.so.1, or is this just a build configuration issue?
Re: Cannot install beta on CentOS 6 due to libudev version issue
Post by martin-k » Sat Nov 21, 2015 1:59 pm
This will work with the next beta. The libudev dependency was added for openSUSE and Mageia and currently breaks CentOS 6.
Return to “General”
