Creating a Quick Path is impossible with mouse
Post bug reports and suggestions here for SoftMaker Office 2016 for Linux Beta that do not fit in any of the application-specific subforums.
tizza10
Post by tizza10 » Mon Nov 09, 2015 8:33 pm
Trying to create or access a Quick Path in the open box is impossible. Clicking on the Quick Path button using the mouse brings up the Path lists/Create A New Quick Path/Change Quick Paths menu, but the mouse is unable to actually do anything, clicking just closes the menu. I can use the keyboard to actually action something just fine though. Ubuntu 14.04 using the third Beta
tizza10
Re: Creating a Quick Path is impossible with mouse
Post by tizza10 » Mon Nov 09, 2015 8:42 pm
Whilst doing some testing, the open box is now not able to close with either the mouse or keyboard.
Post by sven-l » Tue Nov 10, 2015 8:44 am
That issue has been reported and solved. It should work much better with the next beta. Thank you!
Return to “General”
