Wrong standards for Swedish
Post bug reports and suggestions here for SoftMaker Office 2016 for Linux Beta that do not fit in any of the application-specific subforums.
jan-olof
Post by jan-olof » Fri Oct 23, 2015 10:16 pm
Dialog language is right but document language is wrong (en-GB)
Mesurement is USA instead of Metric.
Wrong quotation mark, see image: https://dl.dropboxusercontent.com/u/108 ... tation.png
Using Linux Mint 17.2 Cinnamon edition
jan-olof
Re: Wrong standards for Swedish
Post by jan-olof » Sun Nov 01, 2015 1:22 am
The same errors appear in the third beta too.
Post by sven-l » Mon Nov 02, 2015 4:28 pm
You can change the quotation marks in TextMaker in Tools=>Options=>Language. SoftMaker Office uses the measurements set in your system. Please make sure to use the metric system in your Linux.
jan-olof
Post by jan-olof » Wed Nov 04, 2015 8:29 pm
Yes, of course I can change some settings but they should be correct from the start. The quotation marks cannot be changed as far as I can see (only to English, German or French). They are correct in LibreOffice.
The settings have to be set for each user and separately in both TextMaker, PlanMaker and Presentations. Is there any place where they can be set for all three applications and for all users?
Post by sven-l » Wed Nov 11, 2015 12:50 pm
jan-olof wrote: The settings have to be set for each user and separately in both TextMaker, PlanMaker and Presentations. Is there any place where they can be set for all three applications and for all users?
No, you have to setup each program individually.
Post by sven-l » Wed Nov 11, 2015 1:52 pm
jan-olof wrote:Yes, of course I can change some settings but they should be correct from the start. The quotation marks cannot be changed as far as I can see (only to English, German or French). They are correct in LibreOffice.
The support of Swedish smart quotes is on the agenda for the future but unfortunately not yet implemented.
jeroen
Post by jeroen » Wed Dec 09, 2015 2:19 pm
sven-l wrote:SoftMaker Office uses the measurements set in your system. Please make sure to use the metric system in your Linux.
This appears not to be the case, SMO uses US values, for various settings set differently in my system
eg. I have set the parameters below, but SMO still uses US values for them.
LC_PAPER=nl_NL.UTF-8
LC_MEASUREMENT=nl_NL.UTF-8
LC_TIME=nl_NL.UTF-8
It would be nice if SMO would use the environment parameters to set the defaults.
Post by sven-l » Mon Dec 14, 2015 11:20 am
Which Linux are you using?
Return to “General”
