Works fine on OpenSUSE 12.3, but slow to open
Post bug reports and suggestions here for SoftMaker Office 2016 for Linux Beta that do not fit in any of the application-specific subforums.
ArnaudK
Post by ArnaudK » Mon Oct 12, 2015 10:58 pm
Hi !
I have just tested the product on several documents. Like its windows counter part, minor compatibility issues that seem to be impossible to fix.
However, I noticed that Textmaker takes 4 to 5 seconds to open a very basic document. It runs much faster on TM 2012. Is there a switch / option I can use to trace everything needed for an analysis ?
Jim-J
Re: Works fine on OpenSUSE 12.3, but slow to open
Post by Jim-J » Thu Oct 15, 2015 5:07 pm
Hello,
Please deactivate the SDL engine. You can find the settings at "Tools->Options->System.
Jim J.
Return to “General”
