send...
Post bug reports and suggestions here for SoftMaker Office 2016 for Linux Beta that do not fit in any of the application-specific subforums.
Poltiser
send...
Post by Poltiser » Thu Oct 08, 2015 8:53 pm
1. start any of 3 programs
2. try to send document with e-mail
there are options for evolution, kmail, sendmail but not for thunderbird
question:
how can I use send command with thunderbird?
Xubuntu 15.04 AMD64
darzki
Re: send...
Post by darzki » Thu Oct 08, 2015 9:47 pm
All you have to do is:
1. On 'Client' line select 'Evolution'
2. On 'Command' line change in command line phrase 'evolution' to 'thunderbird'
3. You can select as a client 'Other' and then copy/paste command line from Evolution with changed client
I have tested it successfully.
But still, Thunderbird is quite popular...
Poltiser
Re: send...
Post by Poltiser » Fri Oct 09, 2015 10:24 pm
thank you I will try!
Poltiser
Re: send...
Post by Poltiser » Mon Oct 12, 2015 9:42 am
After I transferred altered command to Softmaker Office it opens thunderbird with correct subject but does not place the document in the attachments... :(
Jim-J
Re: send...
Post by Jim-J » Wed Oct 14, 2015 9:09 am
Hello,
This issue is already reported to the developer team.
Thank you.
Jim J.
Return to “General”
