GoTo Bookmarks
Post your questions, bug reports and suggestions here for BasicMaker 2016 for Windows.
Duncan--
GoTo Bookmarks
Post by Duncan-- » Tue Oct 04, 2016 9:09 pm
I can't find any method in the docs regarding using code to jump to a Bookmark.
Can it be done?
Re: GoTo Bookmarks
Post by sven-l » Mon Oct 10, 2016 1:35 pm
That is not yet possible but on the agenda for future versions:
http://forum.softmaker.de/viewtopic.php?f=176&t=14572
bpm
Re: GoTo Bookmarks
Post by bpm » Sat Oct 15, 2016 1:10 am
In case this is the sort of thing you're after: you can use Sendkeys to manipulate the Textmaker UI.
Here's such a script to open a document & jump to a bookmark:
Code: Select all
Shell "TextMaker.exe"
Sendkeys "^o", wait
Sendkeys "NameOfYourFile{Enter}" 		' include extension
Msgbox "click OK when document has loaded"
Sendkeys "^g", wait					' opens GoTo dialog
Sendkeys "+{Tab}{Home}b{Tab}BookmarkName{Enter}{Esc}"
' sets GoTo selection to bookmarks, enters bookmark name, executes GoTo & dismisses dialog
Such scripts need a way to make sure file ops are complete before subsequent keystrokes are transmitted, or they will be lost. Macro languages I've used in the past have a Sleep command with which you can add a sufficient pause. Not seeing one in Basicmaker, I've used the Msgbox as a quick-and-dirty method. I imagine Basic experts can explain a way of getting the script to handle this.
Return to “BasicMaker 2016 for Windows”
