Worksheet tab right click
tigreseis
Post by tigreseis » Thu Jul 13, 2017 1:55 pm
I tried a search for this issue, but the search kept disregarding words.
This is the first time I have had a problem.
I opened my budget spreadsheet and went to the tab of a worksheet to copy it, but right click wouldn't work on the tab. It wouldn't show the right click menu. It worked everywhere else in the spreadsheet. I could click either mouse button to select a tab (both buttons acted like a left click).
I am using Windows 10. I could use "shift+f10", but that just showed the right click menu for whatever cell was highlighted with black boarders in the sheet itself.
I opened another worksheet and it worked fine in that one.
I have to be able to copy a worksheet within a spreadsheet. I can't recreate it every month.
I put in the USB version hoping it would work, but it doesn't.
tigreseis
Re: Worksheet tab right click
Post by tigreseis » Fri Jul 14, 2017 2:50 pm
No one has any idea?
I downloaded and installed Libreoffice and it handles the right click correctly.
This spreadsheet handled it correctly until yesterday.
Post by martin-k » Fri Jul 14, 2017 2:59 pm
No problem here right-clicking on the worksheet tab. Can you mail the file for testing to forum (at) softmaker.com ?
tigreseis
Post by tigreseis » Fri Jul 14, 2017 3:17 pm
I can't for confidentiality reasons.
Post by martin-k » Fri Jul 14, 2017 3:19 pm
You can remove all calculations and texts from the workbook.
tigreseis
Post by tigreseis » Fri Jul 14, 2017 3:22 pm
It is only this worksheet. All my others work fine.
I can't even move or copy the tabbed sheets with the menus because the options are greyed out.
Post by martin-k » Fri Jul 14, 2017 3:24 pm
Have you protected the workbook?
tigreseis
Post by tigreseis » Fri Jul 14, 2017 3:26 pm
Okay, I did that. Do I send it to anyone in particular or just email it to forum at softmaker.com?
Post by martin-k » Fri Jul 14, 2017 3:27 pm
tigreseis
Post by tigreseis » Fri Jul 14, 2017 3:33 pm
That was it, but I didn't protect it. I had been using the spreadsheet fine for several months. Yesterday was the first time I had a problem with copying a tab!
