Comments movess on first attempt to resize
ccdrop
Post by ccdrop » Fri Mar 31, 2017 12:09 am
The first few dozen times this happened I assumed it was just me clicking a bit off the edges, but after it became noticeably constant I decided to play around with it and see if it was in fact constant and it dose seem to be so.
If you go to edit a cell comment and resize it as the first thing you do it will MOVE the comment instead of resize it every time. No matter how well you have your mouse lined up to show the Up-Dow or Side-to-side Arrow.
Attached in the zip is a video, as .wmv is not a supported attachment type.
Video_2017-03-30_150820.zip
(312.09 KiB) Downloaded 60 times
Re: Comments movess on first attempt to resize
Post by sven-l » Mon Apr 03, 2017 1:37 pm
I can confirm this and will report this issue to the developers.
