How to set GB £ as default currency?
Princy557
Post by Princy557 » Thu Mar 09, 2017 2:37 pm
Whenever I Format|Currency it is always US $. Even though everything refers to UK keyboards, uk dictionary.
Is there a way to set the default currency when formatting to GBP £
Regards
Princy557
Re: How to set GB £ as default currency?
Post by sven-l » Mon Mar 13, 2017 12:56 pm
You can change the currency in Format=>Cell=>Currency. If you want another currency by default, please change the regional Windows settings. PlanMaker uses always the same settings as your Windows.
Princy557
Post by Princy557 » Mon Mar 13, 2017 1:35 pm
Hi Sven
Thanks, for whatever reason W10 had changed it over to US in the Regional. When I checked it the other day it showed both UK and US keyboards. with UK as default, but maybe I accidentally clicked making US as the default. :oops: Sorry to have bothered you.
Princy557 :D
Regards
Princy557
