Different behavior running script from BasicMaker vs PlanMaker
americanaustralian
Post by americanaustralian » Thu Dec 01, 2016 4:16 am
When I run the following script, I get a significantly different result depending on where I run it from. Save the script in BasicMaker. Open a PlanMaker sheet and run the script via Tools=>Start Script. Note how fast the numbers get filled in. Open the script in BasicMaker, then press F9. The numbers get filled in, but not with the same behavior. Why the difference?
Dim pm as Object
pm.Application.Visible = True
Dim row, col, coun, x, pp, dd as Integer
pp = 1000
dd = 35
col = 1
For row = 1 to dd
pm.Cells.Item(row, col).Value = ""
Next row
For row = 1 to dd
coun = coun + 1
pm.Cells.Item(row, col).Value = coun
For x = 1 to pp
Next x
Next row
col = 3
coun = 0
For row = 1 to dd
Next row
For row = 1 to dd
coun = coun + 1
For x = 1 to pp
Next x
Next row
Set pm = Nothing
Re: Different behavior running script from BasicMaker vs PlanMaker
Post by sven-l » Tue Dec 06, 2016 10:39 am
I will refer your questions to our developers and answer here as soon as I have more information.
Post by sven-l » Fri Dec 09, 2016 11:28 am
In PlanMaker the script runs within PlanMaker, whereas in BasicMaker it is executed line-by-line, making sure that the connection still exists after every command that is sent to PlanMaker - it is used to edit and debug the script.
