Equation editor
cpat
Equation editor
Post by cpat » Fri Sep 16, 2016 2:13 am
Despite what the manual says about starting equation editor, I managed to open it, entered an equation and clicked Update to save it in an object on a worksheet. Back on the worksheet I have no idea where the equation went. I'm using rev 757.0510.
Can someone help.
Re: Equation editor
Post by martin-k » Wed Sep 21, 2016 9:03 pm
Did you start the equation editor directly? That's the wrong way. You insert a new OLE object in PlanMaker, select the type "SoftMaker Equation Editor" and enter the equation.
cpat
Re: Equation editor
Post by cpat » Sat Oct 01, 2016 3:59 pm
Thanks!
In my version it says Formeleditor, but it works.
