Printing with Mail Merge
Post your questions, bug reports and suggestions here for TextMaker 2016 for Windows.
beethoven
Post by beethoven » Fri Feb 09, 2018 6:37 am
I just started giving Softmaker 2016 a try and tried to do a mail merge. While I have managed to link an xls file to an amended doc file and created my new template, for this mail merge, I am running into trouble printing the whole set of docs.
I noted the instructions re Properties/View and to uncheck Display Field names and check show merge records in order to preview the form letter with data inserted. According to the instructions you can use print then and print letters individually or print/merge and all letters will be printed. While I can print letters individually, nothing happens when I press print merge. What am I doing wrong?
Re: Printing with Mail Merge
Post by sven-l » Mon Feb 19, 2018 1:31 pm
Upload the document and the database, and we will have a look.
