SMO2016 ofw16_768 update fails msvcrt.dll
Post here those questions, bug reports and suggestions for SoftMaker Office 2016 for Windows that do not fit in any of the application-specific subforums.
DaveW
Post by DaveW » Fri Dec 22, 2017 6:57 pm
Hi,
I received a notice of available update for SMO 2016.
My operating system is Win XP SP3.
After downloading ofw16_768, I tried to run the update, but it fails, with the following message:
"The procedure entry point_except_handler4_common could not be located in the dynamic link library msvcrt.dll."
What do you suggest?
Thank you, DaveW
Dirge
Re: SMO2016 ofw16_768 update fails msvcrt.dll
Post by Dirge » Fri Dec 29, 2017 3:44 am
Hi,
Thank you, DaveW
I also have Windows XP (SP3) and am experiencing the same problem.
PS -- I unpacked the executable file (ofw16_768.exe) and found that the contained setup program (setup.exe) doesn't launch on my computer; it appears to require a CPU with SSE2 support, which my old Athlon XP CPU doesn't have. I suspect that the lack of SSE2 support is the root cause of the update failure, although I don't know how it relates to the msvcrt.dll message. A manual update could be attempted by simply moving the new files in the unpacked executable to their appropriate folders, but some changes to the registry may be needed for everything to work properly. Unless SoftMaker addresses the problem, I'm simply going to forgo the update.
Edit: I misnamed the setup program in the above paragraph: the setup program is spsetup.exe, not setup.exe
Post by sven-l » Wed Jan 03, 2018 8:57 am
I reported this issue to our developers (Ticket 37703) and will inform you as soon as we have a solution. Thank you!
Post by martin-k » Thu Jan 11, 2018 9:43 am
We have now updated the service pack to be compatible with Windows XP again. You need to download it again and then run it.
DaveW
Post by DaveW » Thu Jan 11, 2018 8:40 pm
The new WinXP compatible upgrade installed properly.
Thank you, DaveW
Dirge
Post by Dirge » Fri Jan 12, 2018 12:08 am
Thanks for the fast response. The updated service pack installed without a hitch on my ancient computer (Windows XP SP3; Athlon XP CPU, no SSE2 support).
